Question about Casablanca Fan 3245T Ceiling
Casa Blanca Intellitouch fan buzzing AFTER I ajusted the flywheel
Fan stopped turning and It took the blades off, moved the decoration ring around the motor. moved the flywheel and re-tighten the setscrew put all decoration cover back in place and remounted fan blades. fan started buzzing, light is OFF, if I turn fan OFF it will continue to buzz until the blade stops turning. sound is minimal at lowest speed and get louder with increased speed settings ( think there are 4)
Buffalo12980
  • 625 Answers
SOURCE: Casa Blanca Fan Installation
how wide is the beam - be more specific please.
Posted on Sep 10, 2007
ZTedster
  • 5 Answers
SOURCE: Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Posted on Jun 19, 2009
  • 4 Answers
SOURCE: fan only buzzes when intellitouch control is used
if you have it on a dimmer and not a fan controle then the motor will buzz try to put it on a on and off switch see if that stops the buzzing if it does the go to home depot in the fan section and get a fan controle switch also caled a reastat
Posted on Aug 30, 2009
  • 57 Answers
SOURCE: Casablanca Intellitouch Fan was working fine..
Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
Posted on Jun 10, 2010
espressonist
  • 1711 Answers
SOURCE: I have a Casablanca Panama
There are different parts that might became bad and cause your problem like relay contact, starting capacitor, running capacitor. However all these parts are included in one unit the PCB printed circuit board or electronic board? So you need to replace this parts in attached link is also called RMM.
We have here below a link with service manual for the fan at which on the bottom you will find the parts diagram and parts list. You should try to confirm the part code for your model with Casablanca service department before confirmation of order.
Also please note that you will need a little experience with electronics before proceeding with above operation.
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ConversionKit.pdf
Posted on Oct 31, 2010
The lights suddenly stopped working. It is only about 2 years old. When you turn the switch on they will briefly come on and then go off.
Hello Lisa Gray James,
I had the luxury of having a couple of old Casa Blanca fans in the house when ours went kaput (but the point I will try to make
is quite portable... between MANUFACTURERS.
Typically most wall controlled fans are designed to work over a standard light-switch circuit. the ADDITIONAL functions are accomplish through EACH vendors own proprietary switch-fan interface... (in the Casa Blanca case I am attaching below) they use their "RF" signals from their switch... and the control boards emit audible tone to make the user confident something is working.
I had NOT yet discovered the availability of the replacement unit below... but by swapping the living-room switch with the bedroom switch I was able to prove the trouble to Casa Blanca's 21Z2 control board (inside the fan)
Old style 21Z2: no longer available
Inteli Touch Circuit Board RMM 9901120 or 7801240
is manufacture discontinued (Inteli-Touch & Inteli-Touch II)
but the replacement units (Inteli-Touch 3) will work nicely...
Casa Blanca recommended that BOTH the switch (W32)
and control board should be changed... I complied.
(saved my good W12 switch as a spare)
BUT DO NOT hesitate to call the FAN MAN to discuss your options and needs... it looks like a multi vendor site... and I have also seen them on AMAZON.COM
New Inteli Touch 3 System
Jan 17, 2016 | Dryers
Where to get parts for casa blanca ceiling fan?
are you referring to the light globe? You can go to any home decor or home depot/lowes and find replacement covers, and the make sure the screws the hold it in are not stripped and need to be replaced as well
Jul 20, 2014 | Casablanca Fan Mykonos MyKM45 Ceiling Fan
When I flip the switch it wants to come on and it buzzes but the blades don't go around
The next time you turn it on, try pushing the blades a bit to see if that will get it going. If it does not start running the problem may be as simple as lubricating the shaft the fan blades are hooked to, debris in the motor windings or possibly a wiring issue. Also, the fan blades all hook to a hard rubber ring that holds them to the fan. Be sure none of the blades have broken off this rubber ring.
Please get back to me if these solutions do not prove helpful. Paul
Sep 18, 2010 | Hunter (25417) Ceiling Fan
Fan only buzzes when intellitouch control is used
Aug 23, 2009 | Casablanca Fan Dryers
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Casa blanca fan motor speed control
www.casablancafanco.com
Jul 28, 2008 | Dryers
Sep 10, 2007 | Casablanca Fan 6373T Victorian® Oil Rubbed...
Casa Vieja Probe II Ceiling Fan
look on the side of the canopy there should be a slide switch. if moving this switch has no effect, then either the switch is faulty or the connections to it may have fallen off.
Aug 22, 2007 | Casa Vieja Probe White Ceiling Fan
Casablanca Fan 3245T Ceiling Logo
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
