Question about Motorola Mobility HS850 Consumer Headset
SIGNAL LIGHT CANT TURN SIGNAL LIGHT OFF
  • kayaker999 Nov 27, 2007
    I cannot turn off my HS850 by closing the headset boom any more. It was working before, but not now. Any clue? Thanks.
  • herrgazz Apr 14, 2008
    Closing boom should turn unit OFF per page 11 of manual. My headset continues to blink even with hboom closed, necessitating constant recharging. I used to use it 3-4 days at a time without recharging. Your solution is NO solution!
  • 944 Answers
Here is the link to the user manual; http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/HS850%20Bluetooth%20Headset%20User%20Guide.pdf Check pages 27 and 28, describes all the possible on/off configurations for the signal light. during a call, you can turn it off by pressing volume up and volume down at the same time. If there is no activity on your phone for 5 minutes, it should turn off. What phone are you pairing the headset with? This link gives some more simplified instructions; http://www.motorola.com/mdirect/demos/headsets/index.html If you need the signal light permanently off, then it is not possible without modifying the headset - the easiest permanent way would be to paint over the signal light with a small brush and an appropriate dark coloured enamel paint. It may need 2 or 3 coats to completely block the light. This may possibly void the warranty. You could do the same thing with a piece of black pvc electrical tape cut to fit the light, if you want the option to change back later (probably also need redoing every couple of months). The warranty would not be affected with this method. Another possibility would be to open the unit up, and see where the signal light source LED is situated - don't remove it or disconnect it, but if the legs are long enough, you may be able to gently bend the LED out of the way of the little window to the outside. This would certainly void the warranty. Hope this helps, please ask again if you need more info :)
Posted on Jul 13, 2007
How to replace turn signal relay audi A6 1999
Its in the emergency flasher switch both control the same. The emergency flasher button is above the stereo you have to only remove the radio face plate to get at the switch. remove the red triangle button and put it on the new relay part, good luck,Gary
Apr 16, 2014 | s8 relay turn signal/emerg.light relay...
I replaced my turn signals in my 84 nighthawk w aftermarket one and chopped of my rear liscence plate mount and light now i cant get my new turn signals or front one to work at all. All that happens is the...
cheak to make sure they are wired correctt it sounds like you might of crossed some wires does the indicatoer stay lite when the turn switch is off that would licnence plate light hooked into signal
Mar 06, 2013 | Honda CB 700 SC Nighthawk Motorcycles
Bought a used 1999 Yamaha v-star with some butchered *** tail light and turn signals. Got everything to work except i cant get left or right turn signals to stay on when i turn on the lights, signal...
The marker ("running") lights are a separate circuit than the signal lights.
Normally you have a tail light, and the front running lights on with the headlight.
The bulbs used in the rear signal lights would be a single filament 1156 bulb, whereas the bulbs in the front are dual filament, one for turn signal, one for running light.
Sep 25, 2011 | 2001 Yamaha V Star 1100 Classic
Brake light not work. done all checking blubs is good, replace switch, replace relay, fuse all good. turngal work hazzard light work but no brake light. i bypass on relay it work so i cant leave short...
the brake light switch powers the wire which goes to the turn signal switch. So I think if the turn signals works, then the turn signal switch is bad. Check for power at the wire going from the brake switch to the turn signal switch. . Since you didnt tell what year or model the truck is, I cant tell you what the wire color is.
Dec 10, 2010 | GMC C3500 Cars & Trucks
The passanger side front turn signal won't flash, the rear flashes very fast. I replaced the front passanger side lamp, this did not. can you help me?
the light socket is prob bad, the fast flashing is a built in warning to let you know a turn signal light is out so the "revenue generators" , ( police) cant give you an outragous fine
Oct 20, 2010 | 1997 Ford F150 Regular Cab
I have the left and right blinker figured out. I also have the parking lights and the reverse lights. Coming from the truck the black wire is parking Blue is reverse Yellow is driver blinker and green is...
"Brake," not "break."
Without knowing the year make and model it is impossible to be specific.
But I can say this: Many cars use the same filament (and therefore the same wire to the socket) for the brake and turn signal. That filament is on steady while your foot is on the brake, and the turn signal is not being used. Turn on the turn signal, and that filament is disconnected from the brake-light system by the T/S switch, but is connected by that switch to the T/S flasher.
Jul 01, 2010 | Cars & Trucks
I removed my turn signal to get fender painted. I
on the side of your bike in the rear. you have two long brackets where the light mount. under the fender to the brackets from your rear light..then under the fender again to the front from your light this is the rear light harness. if you have a problems go to local auto store i get the hanes shop book this will help considerly..
Apr 18, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Brake light and turn signal light not working
Did the new lens come with new sockets? If not damage may have occured there that you cant see. only other possibilty is wiring damage in the rear that may be hard to see. The condition you describe is simple "backfeeding" if you look hard enough youll either find bad sockets or damaged wires close to the lens that took the hit. Hope this helped. Thanks
Apr 06, 2009 | 2004 Jeep Liberty
My turn signals will blink very fast until I jiggle the turn signal arm, sometimes turning on the bright lights accidentally. Now only the back left blinker (turn signal) will not come on until I jiggle...
check ur connection....check ur light bulbs front and back and replace the ones who dont work....also undo the stearing casing and look for loose or broken wire...if problem cant be fixed bring it to a auto electrician....
good luck
Mar 07, 2009 | 1998 Chevrolet Lumina
1994 ford f150 turn signal
check your fuses, something is blowing out your bulbs or causing a lack of electrical support, and cant support all your lights working at once...let me know how it goes
Nov 25, 2008 | 1994 Ford F150 Styleside Supercab
Motorola Mobility HS850 Consumer Headset Logo
62 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
