Question about Supco HVAC Control Transformer - SXT105
Supco transformer, sxt105 - Supco HVAC Control Transformer - SXT105
How is the conection ofSXT 105 to 117 VAC
This is the computer section, please post correctly.
Jul 05, 2017 | The Computers & Internet
Emerson model#CR519B. The unit just stopped working. If plugged in a motor runs for about 8 seconds and clicks off; about a minute later it repeats. Help
I had the same problem with a small wine cooler. It happened to me twice in 6 years. Both times I had to replace the starter relay.
I couldn't find any repair facilities willing to work on these small wine coolers or refrigerators, probably because the bill would be more than the used fridge is worth. If you feel confident around a volt/ohm meter and electricity, you could learn how to test this and maybe fix it yourself.
You shouldn't do any of this if you aren't familiar with using a Volt/Ohm meter and can safely and confidently work around electricity.:
  1. Unplug the fridge
  2. I first tested the compressor with an Ohm Meter (see how with youtube video below or by reading how at Davesrepair.com). It was good, but it kept starting and stopping within a few seconds.
  3. Basically my starter capacitor/relay wasn't working. It supplies temporary starting voltage to the starter relay in the compressor, then cuts off to allow the motor to run.
  4. I bought a Supco 3-in-1 on Amazon for less than $13 and hooked it up according to the supplied instructions. It lasted about 3 years.
Of course, the factory recommended repair is to buy the original replacement relay, but it will be more costly and harder to find.
I bought a Supco 3 in 1 Hard Start relay sized for the HP on my compressor. Mine was the Supco RCO810 (see link below).
NOTE: Before I replaced the starter relay and overload protection with a Supco 3 in 1, I learned how to test the compressor with a Volt/Ohm meter. If you don't have a meter, you can buy them online or inexpensive to free with a coupon at Harbor Freight.
Feb 15, 2015 | Emerson Refrigerators
How to install supco pulg in receptacle
you will remove power from unit , remove old receptical cut wires close to old unit then splice new wire into old polarity is not important
Nov 26, 2013 | Supco RR110 Plug-In Receptacle for...
Ge gss20iemb
Valve is GE WR57X10032
Replace with SUPCO WV10032 sells on Amazon for $17.76 There is usually a sheet inside package with diagram
Amazon com Supco WV10032 Refrigerator Water Valve Replaces WR57X10032 Home...
Jan 06, 2018 | Refrigerators
Supco wiring an old freezer. Orange wire?
Was the orange wire on a switched live on the old compressor connections? It may come on when the compressor goes off in that case. If not, recheck the schematic for the other end of the heater. If it has a neutral, join the orange to the live feed to the supco. If it has a live, leave the orange on the neutral of the supco.
Apr 21, 2012 | Refrigerators
Compressor stops running and keeps cycling every few minutes. It buzzes as if the compressor is gone. the compressor is hot. If the thermostat is turned to off for 6 to 8 hours and then turned back on the...
you can replace the relay with a 3 in 1 made by supco. i generally just use a supco 0410.
www.supco.com
it is a start relay, overload, and start capacitor all in one. works great for residential systems.
Nov 06, 2009 | Frigidaire FRS3R5EMB Side by Side...
Maytag MZD2766GEW No Cooling
hi thanks for the question . i would replace the relay and the cap then your sure your good to go. thanks te appliance doc rate me please
Oct 01, 2008 | Maytag MZD2766GES Side by Side...
Supco HVAC Control Transformer - SXT105 Logo
Top Supco Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
Are you a Supco Heating and Cooling Expert? Answer questions, earn points and help others
