Question about Epson Dc 11 Doc Cam Elpdc11 V12H377020 Projectors
Pink lines lines appearing on screen
A pink line the whole height of the monitor has
Try setting you screen size to a larger or lower size. and the pixel color. try 32bit instead of 16bit.
Jul 18, 2009 | Acer 22" X223w LCD Monitor
Pink line down screen
I have a laptop that has been doing exactly the same. It started off with a fine pink line. After almost a year it now has gotten wider and has white lines and all other colours. It could work like that for quite a long period. It is a conection in the bottom of the screen but is so delicate... Only way to REALLY fix it is to have the screen replaced which could be quite an expensive thing to do
Jul 06, 2009 | Sony VAIO VGN-FS640W Notebook
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
My Xerox 6130 keeps printing vertical pink lines on pages
your color laser printer pink vertical line appear on the roller and film drum,
1) you need check the pink drum surface, it got damage if you find there is a different color vertival line on the drum surface, so you need change the pink drum.
2) check the pink drum cleaner (call brush to return the waste toner), it can not clean well sometimes, if the drum surface good.
Feb 06, 2009 | Xerox DocuColor 12 Printer
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Pink (Magenta)vertical line appears on the screen
Vertical magenta lines could be a symptom of a loose connection to the optical assembly,or a source of interference. Try resetting the TV first - unplug from wall socket for about 2 hours, replug, and see if it works.
Also check the cables/connections from your cable box, etc and see if the issue can be resolved by manipulating the wires. Could be a loose connection..
Oct 03, 2008 | Philips Televison & Video
Panasonic plasma hdtv with crazy red coloring
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
Epson Dc 11 Doc Cam Elpdc11 V12H377020 Projectors Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
