Question about Hitachi 60V710 60" Rear Projection HDTV
Tv won't come on
I have the Hitachi 60v710 rear projecton hdtv screen and the temp and lamp led's keep blinking and the tv won't come on
    Problem Solver:
  • 4 Answers
I had the same problem took it to the repair shop and they replaced the bulb.Works fine now.
Bulb cost 199.00
Posted on Jan 26, 2009
Hitachi tv 60v710 turns off and on by its self every minute what it can be?
This problems it is related to the tv projection lamp.The tv projection lamp is inside the tv now.Been in the tv like a 1 1/2 or 2 years already?Tv is on and used it like 4 or 5 hours daily?Yes,than the tv projection lamp must be replaced should solved this problems.If the tv projection lamp already been replaced,than this problems are caused by the board that call the Ballast board.This Ballast board only job are to ignite the tv projection lamp only.
Jul 13, 2011 | Hitachi 60V710 60" Rear Projection HDTV
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
My tv went out the other day completely but when i turn it on there is no picture but there is a flash on the lamp light and temp.
Most likely bad lamp . Listen for a very slight buzz from the rear of tv at power up. IT will buzz several times before lamp light begins to blink. IF it does and pix does not light suspect lamp .. Part number Ux21513
Feb 16, 2011 | Hitachi 60V710 60" Rear Projection HDTV
My Hitachi 60v710 HDTV does not come on and when in off position lamp lite is red and when on lamp and led blinks red and power blinks blue what is wrong and can I fix it myself
Did you say the lamp blinks red? I assume you meant the lamp status indicator light. That probably means the lamp is burned out. Take the lamp assembly out and inspect the bulb. If you see a visibly burned capsule or broken wire inside, that's your problem (you don't need to remove the lamp from the assembly to inspect it, and don't touch the lamp itself - see next paragraph). When you replace it, be sure you clean all of the vents in both the front and back of the set. Dust-clogged vents will cause a bulb to burn out prematurely, or even explode. You may need to remove the back cover (unplug first!) to clean out a dust filter for the lamp cooling duct.
You can save money by buying a bare bulb and rewiring it into the lamp housing, but be absolutely careful never to touch the new bulb with bare fingers - the contaminants from your fingertips may cause the bulb to explode when it gets hot. Wear disposable vinyl gloves (the kind restaurant food handlers use) for this job. The gloves may be included with the new bulb.
Set a regular cleaning schedule for the vents. How often depends on how quickly the dust builds up. Just don't let them get completely covered with dust.
Sep 22, 2010 | Hitachi 60V710 60" Rear Projection HDTV
Tv turns on and off every 5 minutes
The projection lamp has not been change in this tv the last 1/2 or 2 years?The tv on an used watches 4 or 5 hours of tv a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Aug 30, 2010 | Hitachi 60V710 60" Rear Projection HDTV
When I turn the TV on the temp and lamp lights keep blinking
You probably need a new lamp and check the fan for the lamp if it is inop or to dirty it will not cool the lamp properly. Address these issues first and let's hope you have not blown the thermal fuse.
Jan 25, 2009 | Hitachi 60V710 60" Rear Projection HDTV
Blinking lights
buy this lamp p/n UX21513 but first take out the old check it should be blown by what you say..
Oct 05, 2008 | Hitachi 60V710 60" Rear Projection HDTV
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 60V710 60" Rear Projection HDTV Logo
224 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
