Question about Asko D1876 Dishwasher
Asko d1876 is there a reset switch? i have cleaned lines, drain and no water anywhere-- f2 still flashing-- any reset switch other than circut breaker?
I have a D1876 it stopped draining in cycle all lights flashing and F2 . anyone know what to do
Posted on Jan 23, 2010
  • robocam Jun 29, 2011
    Is There water in the bottom tray, ifso there is a leak from some point .Youwill need to remove the rear panel and see if you locate where the water is coming from. One place may be on the flange of the main body of the pump assy. There is a rectangular hole that some times allows water to seep between the tub body and the pump housing gasket. This is due to the locking ring that secures the main pump assy to the tub failing. The thread and the flange part company thus any tension to seal the pump body to the tub is lost. This now has a modified ring assy by asko and is a different material to the OEM ring.Hope this helps
I'm not sure about that model, but on an older one, just under the drain area there is a piece os styrofoam attached to a switch. I guess if it rises it activates the circuit. Problem is if it drys it sticks, so push it down with your hand gently. This involves taking off that bottom kickplate area, but that's the only way in there.
Posted on Apr 29, 2009
F2 and all panel lights flashing part way through cycle. Machine will not switch off unless you switch power button off
Hi
You have water in the bottom pan.Turn off power Remove bothe front and rear lower panels and dry out pan with a towel after tipping water from pan. Turn on power and try operating the washer and look for water leak. It could be coming from a number of places. The repair will be what ever is the cause of the leak. F 2 = water in the pan. Hope this helps. Rgd Robocam
Mar 07, 2011 | Asko D1876 Dishwasher
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Asko d1876 dishwasher
The F2 lights blink due to a water senser in the compartment where the motors are located. Remove the bottom kick panel and other covers to access this area of the unit. Unplug the unit before working in this area as wires are abundant. Check the pan to see if water is present. Dry out the pan with a towel and then maybe a hairdryer to clear the F2 alarm. The real questions is what caused the water to be there. Start a cycle and watch to see if there are any leaks on the inlet water line. If not, let the unit run and see when water enters the pan. If it enters during the washing cycle, a gasket leak is likely. If it enters during the drain cycle, perhaps a drain hose is leaking.
Feb 05, 2009 | Asko D1876 Dishwasher
F2 FAULT AND ALL LIGHTS ARE FLASHING.
f2 means water in the flood pan remove dishwasher from under bench and tip back the water will run onto the floor.then test the dishwasher while it is still out you can remove the rear panel were the hoses go through and check the drain hose for leaks also check the white plastic ring under the metal filter for cracks,they look like a dark line.as far as the dispenser the most common cause is the main board,remove door skin and control panel and check the back of the board for damaged tracks,you will also have to replace the wax motor(red) on the drying fan(if fitted)check the solenoid on the dispenser for open circut.hope this helps.Ian.
Mar 17, 2008 | Asko D1876 Dishwasher
Asko Dishwasher F2 Fault
i have an asko washing machine that is displaying f2 how do i fix this problem myself without calling any one in
Jan 21, 2008 | Dishwashers
Not completely draining - F2 error
i would check the screens in the tank first make sure their clear.if not then shut the water off and check the hoses,let me know.
Nov 10, 2007 | Asko D1876 Dishwasher
F2 fault
The F2 error codes relates to high water level It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. As well it could be a defective or a malfunction pump. Good luck!
Sep 05, 2007 | Asko D1876 Dishwasher
Open Questions:
See all Asko D1876 Dishwasher Questions
Asko D1876 Dishwasher Logo
586 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
