Washing machine edesa 1L -84 what is the k? - Washing Machines
4 Suggested Answers
  • 6277 Answers
SOURCE: Please I need an instruction
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 22, 2011
  • 6277 Answers
SOURCE: where can I get English
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 16, 2011
SOURCE: i have an edesa l-2086
Did you ever get one? I have the same problem; I removed the door and dismantled near the catch. Then I put a loop of strong string round the hook. This works fine as I simply pull on the loop whilst pushing the door in slightly to take pressure off the hook end. The weak handle is a design flaw. If you find a source for a new catch please let me know. C
Posted on Dec 18, 2011
How to fix an E6 srror code for the washing machine
believe it to be a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to drain the water, from the pump then unscrew the large drain cover and remove the blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II in the top and setting the machine to 'drain'. it should beging to drain
Dec 12, 2016 | Washing Machines
My wash machine miele W145s is stopping washing when comes to rincages point. The lamp is flashing. Have somebody any suggestions in addition to buy new one?
Look in to filter housing and check that no debris is entangled in the pump impeller also check the drain out pipe for blockages
Dec 26, 2014 | Miele Washing Machines
Where can I get English instructions for an Edesa LT1005 washing machine
Manual
John C.
Jul 16, 2011 | Washing Machines
I have an edesa l-2086 washing machine can anybody tell me where i can buy a replacement door catch in murcia (spain) area
Mar 29, 2011 | Washing Machines
I have an error code E6 on my Bosch Front Loader Maxx Washing Machine, can you please advise what this error is and how to fix??
Hello there
Normally this is a drainage problem code
Mar 07, 2011 | Washing Machines
Please I need an instruction manual for my washing machine Edesa L-511 Eco Princess. In english please.
Good luck,
John C
Feb 22, 2011 | Washing Machines
Need new cutlery basket for edesa le15p
The brand Edesa is somewhere from Europe; thus you would not be able to find the basket anywhere in the U.S.
http://www.appliancepartspros.com/
Feb 14, 2011 | Dishwashers
How do you reset a beko washing machine??
It's actually pretty easy. Try this: press and hold the start button in for 5 seconds.drain pump will start up.let it complete its routine (takes 2 mins or so).now the machine has reset.select program as normal and retry
Hope this helps
Dec 26, 2010 | Washing Machines
Beko wma765s washer error code 1L and flashing 1200 spin light washer completed wash but when went to load up again refused to start and 1200 spi n light flashing as well as flashing 1L in time remaining...
Main board fault.engineer says not worth fixing.sourced board and replaced myself cost me £50 but have seen it priced at £63 and £86 .got mine by phoning Beko spares. took 10 days tho.as not in stock
May 17, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
