Question about Danby DPAC12010H Portable Air Conditioner
Heat dont work
Its not that old july 22, 2011 i bought for air, but i tried the heat & its not really getting warm
We have the GE sensor microwave WES1358DN1WW. It was made in 5/2009 & bought in July of 2010 brand new. it worked perfect til last week. i put something in it & it started to make a loud...
It's really a pain to open them up but if your feeling up to it, it sounds like the magnatron has vibrated loose and probably disconnected a wire. Disassemble and take a pic if u need help. It's pretty straight forward once inside
Apr 02, 2017 | Vacuums
I Have a 2003 Yukon denali & I dont get no heat i change the thermostat & antifreeze but no heat
1) Check your water pump is working OK and
2) You may have an airlock in the system. Take the expansion or header tank cap off, set your heater control for hot and exterior air. Start the car and run it till warm. With luck you'll run any air locks out of the system. While warming up, and being very, very careful, try squeezing the main radiator in and out tubes (The fattest) this may also move any air locks on. BUT BE CAREFUL, STAY AWAY FROM AND FANS AND PULLEYS. IF NOT SURE, DON'T DO IT OR STOP THE ENGINE FIRST.
With luck, you should soon start to feel warm air coming from the vents.
Mar 29, 2011 | 2003 GMC Yukon Denali
Hello, I have an 86 olds cutlass and i just bought it and the heat was working fine...now it wont blow at all. it seems to work only when it wants to....sometimes its real good,other times real week...it...
when you say it works then dont want part of heater you talkin about the warm air ,heater fan ? if its fan it unbolts at fire wall on passenger side. not alot of $$$$ better than freezin....
Dec 28, 2010 | 1986 Oldsmobile Cutlass Supreme
How to wire Honeywell thermostat RTH7500 from old Weathertron GE
You have a control board on your furnace, there is a 3 amp fuse there, that 3 amp fuse needs to be replaced. You most likely touched a wire even by accident and blew the fuse. You will have to remove the door \panels to get at it. It looks like a normal car fuse
May 31, 2010 | Honeywell Electronic Programmable...
Blowing moteratly warm air
SOUNDS LIKE YOU ARE OUT OF FREON. A LEAK OR SOME KIDS SNIFF THE FREON. OLD ONES TAKE FREON 22 NEW ONES MAY TAKE 410A
Apr 20, 2010 | Mitsubishi MS-A09WA Split System Air...
No heat just warm air
I think you are on top of your problem,,you dont need any one elses advice.
Complete rebuild of the cooling and heating system,, simple.
Jan 19, 2009 | 2001 Oldsmobile Alero
Heat not working
Potential easy solution; check whether there is a vacuum operated valve in the heater supply or return lines. My old v8 '84? Malibu had one. It kept coolant from circulating through the heater until the motor warmed up; helps warm the engine quicker; BUT it was stuck closed and I had no heat. Rather than purchase a new one or mess wqith the vacuum lines, my solution was to use a piece of wire (nylon zip tie might work also) to hold the thing in the open position. So the motor takes a minute longer to warm up. Else might be air embolism in the line, which could indicate combustion leak or insufficient purging of air from the system after you changed the t-stat. Good luck.
Jan 14, 2009 | 1994 Chevrolet Silverado 2500
Heater blowing not so hot
How hot this gets is often regulated by the engines ability to properly heat up. This is controlled by the engine thermostat. Alot of times, people who have an overheating problem simply remove the thermostate without replacing it. This does not allow the engine to heat up properly (it actually is running too cold) thus the water coolant does not heat us. result, barely warm air through cabin heater.
Nov 21, 2008 | 2001 GMC Sierra C/K3500
Danby DPAC12010H Portable Air Conditioner Logo
14 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
