Question about Ovens
I need to reset my Beko Leisure GR6GV cooker clock
kachbibi1
  • 979 Answers
SOURCE: I need to reset the clock on my AEG cooker model No S75408 KG
I am assuming you have a touch pad for the clock. You can hold down the time button for a few seconds an it should start blinking. If it doesn't work, try pushing the "set" button for a few seconds. Usually, you can find it by trying all of the buttons til you get the right one. Then, you can adjust the time by moving the up and down arrows.
Posted on Jan 30, 2009
SOURCE: beko dvc6531 cooker
i can send u a copy of user manual if you need one you have to hold the first two buttons in then move time with up or down please email me if you need more info andyali09@btinternet.com
Posted on Aug 30, 2009
barkencoa
  • 3463 Answers
SOURCE: Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Posted on Jan 07, 2010
  • 3 Answers
SOURCE: beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
Posted on Sep 17, 2010
  • 417 Answers
SOURCE: Beko dv555w electric cooker.Oven and
Hi
check that the cook mode is set to MANUAL, as if its on AUTO it will not come on.
Posted on Dec 20, 2010
Both ovens in my gr6gv leisure dont get hot enough
http://leisurecooker.co.uk/Manuals/BrochuresManuals See if this can be of any help Kolbrun
Sep 18, 2013 | Ovens
Instructions for lighting grill for Leisure Cooker GR6GV MKII
Have your flame next to the pilot light before turning on. Hold pilot knob in while lighting. Hold it in for about 30 seconds once it is lit. Then you can turn it to the on position and set the temp.
Feb 24, 2013 | Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
The digital clock on my beko dv555 cooker isnt comin on and as my cooker was on timer now my main oven doesnt work either but my grill and hobs do
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Mar 09, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Nov 19, 2010 | Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
May 16, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Beko dvc6531 cooker
Jul 13, 2008 | Ovens
Ovens Logo
81 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
