Question about Bosch Dishwashers
How do I set the Salt setting On Bosch Classixx SPS40C12GB
Classixx SPS40C12GB
3 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: My Bosch Classixx dishwasher is
In order to rinse dishes and glasses satisfactorily, the dishwasher requires soft water, i.e. containing little or no lime, otherwise water stains will be left behind on crockery and glasses, etc. If the tap water exceeds a certain level of hardness, it must be softened, i.e. decalcified, so that it can be used in the dishwasher. his is achieved by adding a special salt to the water softener inside the dishwasher. The water softener, that is the required amount of salt, is set up according to how hard the tap water is.
Setting up the water softener
Determine the level of hardness of your tap water. Your local water company or service agent can help you with this. Identify setting from the following water hardness table.
Press and hold the B programme button, and set the main switch to ON, before releasing the programme button again.
The indicator lamp for the B button flashes, as does the figure in the numerical display. The latter represents the value that was preset in the factory.
To change the setting:
Press the B programme button.
Every time the button is pressed, the figure increases by one. After reaching 7 the display starts at 0 again.
Set the main switch OFF. The new setting is stored in the appliance’s memory.
Approx. 4 litres of water are required for regenerating the water softening system. The overall water consumption per load can therefore be increased by between 0 and a maximum of 4 litres according to the water hardness setting.
Posted on Oct 11, 2009
  • 457 Answers
SOURCE: Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Posted on Feb 26, 2010
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch Dishwasher using too much salt
This will be the regeneration valve sticking in the open position. It is located on the regeneration unit behind the left side panel (looking from the front). It is fairly easy and inexpensive to change....however, the cheapest fix (if you are not in an extremely hard water area) is to switch to an all in one tab and not put any salt in at all!!!
May 13, 2013 | Bosch 24 in. SGS43C12 Classixx...
The salt and rinse aid lights stay on
Top up salt and rinse aid or just ignore the lights if you use 5in1 tabs.
Apr 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx 1200 wont start. Ready light is on, door is firmly shut, but start button does not do anything?
these things can be confusing! you may have it set on 'delayed start' or 'soak'- check the other indicator lights! 'soak' would fill and pause for a while, while 'soaking'- 'delayed-start' can be set for an 8 hr. delay on our fridgidair front-loader. don't know about the bosch!
check settings. if ready light is on, there doesn't seem to be a problem with door latch.
good luck!
Oct 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch Classixx dishwasher is using all the salt in one wash.Why and how do I resolve?
Oct 11, 2009 | Dishwashers
How much salt should you use in a refill of a dishwasher in a hard water area
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Water hardness is measured in either European °E (clarks) or in the German °dH ( Deutsche Härte) you will find this on all Bosch Dishwashers here is the comparisons for the two.
If your water is Very Extremley hard then you will need to program your Bosch dishwasher using the Code
H:06 to give you maximum protection here is a comparison table for the codes and the Clark and Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
Sep 30, 2009 | Bosch 24 in. SGS43C12 Classixx...
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Dishwashers Logo
593 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
