Question about Casio Exilim EX-Z57 Digital Camera
Memory Full Need help! Camera takes 5 pictures and then says "memory full". I have used new memory card, formatted from Menu and still only 5 pictures. 5 pictures with or without card, so I guess the camera has stopped readaing the memory cards. Any solutions?
  • Colin Philip Jul 13, 2007
    Memory card is 1GB - should take about 550 pictures on this card. My other card is128MB and usually takes 54 pictures. There normally is loads of memeory
  • Colin Philip Aug 29, 2007
    Hi everyone, sent the camera back to Casio and they put in a new memory board £72.
    Thanks for trying
    Genius:
  • 2,985 Answers
What size is the memory card. What picture size has the camera been set to? Check out your Manual for the images sizes viz a vis memory card capacity - and come back
Posted on Jul 13, 2007
  • john ash
    john ash Jul 14, 2007
    Report this the the Makers Tech Support Team on their Website.
    This appears to be a firmware fault.
    Nothing you can do about it.
    Check out the manual to see if there is a Reset feature- but I doubt it.
Menu -> Setup -> Format -> Format to format your memory card and regain all your storage!
Posted on Aug 24, 2007
SOURCE:
My Casio ex-z75o is only taking 7 photos before it says memory full i have tried different memory card but no change
Delete the photos off the internal memory and remove the battery. this will reset it the factory setting and that should clear it up
May 03, 2014 | Casio Exilim EX-Z750 Digital Camera
The camera says memory full when I try to take a picture even thought I just put a new memory card it in
You probably need to format your card. Look thru the menu on your camera...there should be a place on the help menu, which allows you to format your card.
Aug 21, 2011 | Polaroid iZone 300 Digital Camera
"Memory full" displays on screen.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Feb 12, 2011 | Nikon Coolpix L1 Digital Camera
Brand new camera, unable to take any pictures. Internal memory is full. Even when we put a mmory card in place, still thinks internal memory is full. Why doesn't the camera use the memory stick to save...
If you used the internal memory even once, the memory card will not work until you get rid of whatever is in the internal memory. Do this...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Dec 28, 2010 | Kodak Cameras
I can only take like 2 to 5 pictures on my Canon PowerShot A530 then the memory card says it's full.
Actually, your camera is probably telling you the internal memory is full. To get the camera to write to the card, you need to get rid of everything on the internal memory. Here's how...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Nov 17, 2010 | Canon PowerShot A530 Digital Camera
Memory card is always full even though it is new
Hi, The solution is to format the memory card or initialize the memory card. Note formatting the memory card will delete all the pictures or data stored. Formatting memory card
1. Press the MENU button in any mode.
2. Move the 5-way scroll button to the right and press the confirm button to enter the SETUP menu.
3. Move the 5-way scroll button down and enter the FORMAT menu. Press the confirm button and the "Format?" dialog box appears. Select "Yes" to start formatting. Select "No" to cancel.
Apr 12, 2010 | DXG Technology DXG-409 Digital Camera
My camera keeps saying the card is full when its brand new
You just need to format the memory card. And make sure that you are in memory card option for the picture storage when you take pictures.
Formatting the memory card This function will format the memory card and will erase all files in memory including files that have been protected. Note: Once formatted all the images stored in the memory will be erased. This process is irreversible. Please download all images to the PC before formatting the card. 1. Touch the icon (arrow down) function area until you see the “Format” option.
2.Touch the icon (memory card drawing/picture) function area to enter the Format menu.
3.Touch the icon (arrow left) function area to select OK/Cancel.
4.Press the Menu/OK button to confirm.
5.A Format message will appear on the LCD.
FORMAT?
YES NO
6.Touch the icon (arrow right) or (Arrow left) function area to select Yes or No.
Apr 12, 2010 | Vivitar ViviCam 8025 Digital Camera
Internal Memory full; No memory card in; Will not take pictures;
You need to get a memory card and promise to never use the internal memory again....it only causes problems as you have found out. When you get the new card follow this procedure: 1. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to format the internal memory. 2. Insert the new card and do the format thing again to prepare the new card. Happy photography!
Mar 14, 2010 | Kodak EASYSHARE Z1285 Digital Camera
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
[email protected]
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 13, 2009 | Cameras
When taking a picture it will not go to my memory card
i recently added a new memory card to my camera,i have selected auto in image storage under menu button my internal memory says full and i have deleted all memory and internal memory pic and it still says full internal memory and won`t let me take any pics,what can i do on this matter?
Apr 19, 2009 | Kodak EasyShare Z760 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
337 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
