Question about Honeywell Hardware & Accessories
Wiring a grasslin thermio touch to a sabre 29 he
What connections
Just fitted a gasslin thermio touch room thermostat and my boiler won't turn on
YOU SHOULD HAVE A LIVE IN & A LIVE OUT THE NUETRAL WIRE IS NOT USED, SO TAPE IT OFF & HOOK THE YELLOW WIRE WITH STRIPE IN IT'S PLACE. HOPE THIS HELPS, GOOD LUCK.
Dec 27, 2012 | Heating & Cooling
Just wired up the gp24 ,connected mains,switch and nuetral, working on manual mode but clock not turning
Reverse wires on terminals 3 and 4
1) GP24 appears to be 24-Hour version of Greenbrook T100 series mechanical timer, with Grasslin analog time dial.
http://waterheatertimer.org/pdf/Green-brook-T100_CInstructions.pdf
http://waterheatertimer.org/How-to-set-timers.html
2) If clock is not rotating, then probably your wires are reversed.
Reverse wires on terminals 3 and 4.
3) Power from Mains, and wire to Load each have 2 wires.
Hot live from Mains connects to terminal 3
Neutral from mai9ns connects to terminal 1
Neutral going to load connects to terminal 1
Hot going to load connects to terminal 4
Dec 08, 2012 | Hardware & Accessories
Grasslin ecosave timer not working
Add a comment and say if the timer worked before and stopped working, or if this is new installation that does not work correctly.
Otherwise the timer expert is guess that the problem is incorrect wiring, defective timer, tripped circuit breaker, or if the clock motor has gotten weak over time, and stopped working.
Or, Contact Grasslin UK:
http://www.grasslin-controls.co.uk/ecosave.html
Aug 25, 2012 | Hardware & Accessories
Grasslin timer instructions
Grasslin timers and manuals
Click timer-categories on left to see drop-down menus
http://www.intermatic.com/products/grasslin.aspx
Grasslin electronic time switch
Click on model number and drop-down menu shows manuals
http://www.intermatic.com/products/grasslin/electronic%20time%20controls/electronic%20time%20switches.aspx
Oct 11, 2010 | V, Inc. 12v Dc Timergeneratortransfer...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
The new battery on my 2002 honda shadow sabre won't stay charged. Even with the bike turned off, the battery drains. Does my type of moto have an alternator in it? Or is there a broken fuse draining my...
please check your rectrifier. or simply do this to check if there is a short circuit,
turn it off
detach the positve wire on the battery
then put it back again
when the wire touches the positve pole and spark, it has a short circuit
disconnect it and check the wiring
Apr 18, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Wired incorrectly need wiring diagram
I have baxi combi boiler genesis 80 and grasslin timer need to no what wires go were there are 4 wires coming out the timer red and brown together white and blue the timer is internal one can you help
Mar 18, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Hardware & Accessories Logo
51 people viewed this question
Top Honeywell Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Honeywell Hardware and Accessory Expert? Answer questions, earn points and help others
