Question about HP iPAQ HX2700 Pocket PC
My unit turns on but I cant proceed from there.
After I turn the unit on I cant do any other function from there.
I am an amature when it comes to computers. I have had the unit for about 1 1/2 years. I never got to use it because it froze up right away.
I put it on the shelf and meant to get it fixed but time went by, [health issues etc.] the other day I was year end cleaning and found it. I would like help getting it fixed. Can you help me?
  • HP Master
  • 13,433 Answers
Hi
try a hard reset instructions on this page
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?locale=en_US&taskId=110&prodSeriesId=421420&prodTypeId=215348&objectID=c00266789
if the hard reset doesn't solve the problem we have two possible solutions
1. Reload the internal software.
2. there is a hardware problem that requires service.
Posted on Jan 26, 2009
    Genius:
  • 1,550 Answers
Most likely the battery is defective.
Try with new one .
Cant calibarate my HLX 1500 whatt INFAREDheater
I would not bother with calibrating this unit. The problem with doing so is that you will have to do it every time you move it. I tell people to run it at a higher temp. When you are comfortable turn it down until the relay clicks the heat off. The unit will maintain that temp.
If you are insistent on doing it anyway this is the procedure;
Plug the unit in, keep it off. Hold the enter button. You will see dashes across the display. Hold until STS Y(N) comes up. press once FSP Y(N) comes up, again then TD 1 comes up and one more time TA 00 comes up. TA 00 is the calibration function. use up or down to turn the calibration in either direction up to + or - 10 degrees.
Jan 20, 2014 | Washing Machines
Air conditioner wont work
When the STOP indicator light turns on, the internal water tank has filled with condensed water and the air conditioner will turn off automatically. You can drain the internal water tank by removing the plug on the back of the unit, be ready for a lot of water to come out of the unit. The unit will shut down when the water pan is full. This condition may occur either when the unit is operated in high humidity conditions, or when the unit is being operated in HEATMODE, since the auto-evaporation function will not work in the heating mode. I hope this helps, have a great day, Andy K.
May 22, 2013 | Heating & Cooling
My Kenmore Ultra Fabric Care Model 110.82884800 fills and agitates but then stalls and will not proceed to drain, rinse, and spin. If I smack the top of the machine several times :) it will kick into the...
Possible failure of the program controller unit as if fails to advance forward , this can be due to failure of the stepper motor which needs to move the program forward. try and use a degreasing spray to free the movement if there is visible dirt seen
Jun 11, 2012 | Kenmore Washing Machines
When you turn the unit on a message comes onto the screen that says. UNIT CURRENTLY CONTAINS NO MAP! INITIATING MAP UPLOAD. you cant do anything with the unit message stays on the screen.
when you turn the unit on a message comes onto the screen that says:
May 01, 2011 | Magellan eXplorist 400 GPS Receiver
Cant get my dimplex club electric fire to come on
Do the rest of the functions of the fireplace work? If so, turn the Master On/Off Switch to OFF and plug the unit for 12 to 15 minutes. After the time has elapsed, plug the unit back it and turn the Master On/Off Switch to ON. Then turn on the flame function switch. Hopefully, that timeout allowed the unit to reset itself and the flame function is now working. If it isn't, either the flame function switch is faulty or the circuity to the light bulbs and the ro-tater motor that turns the shaft, that he bulbs are attached to, has failed. Without knowing how old the unit is and how much use it's had, it's hard to pin down one thing that is causing the problem. If it's any consolation, you are not alone. Hundreds of these electric fireplaces (all makes & models) fail every year.
If all else fails, contact Dimplex USA, Technical Service at 888-346-7539.
Hope this helped to solve your problem.
Mar 17, 2011 | Heating & Cooling
My tv was repaired. The color wheel was replaced. After just a few weeks I'm having the same problem. The picture will turn red, green, snowy and then the screen will go blank and then a message of...
Professional replaced ur tv colors wheel?Or u replace it?Amature people replaced things,that require take out alots of machanicals parts are 50/50 chances put it in wrong or missing some crusal connections,than the parts they put in will be functional for awhile and dies,than the parts is junk.Re examine the colors wheel,that was put in.Recheck all those machanicals parts and those wires plugs in connections was taken out put back correctly and tightly.
Oct 28, 2010 | Samsung DLP HL-P5663W 56" TV
My main screen Doesn't Turn On
There is a power switch on both units. The second screen will get power if the power switch is turned off on the main unit.
Apr 12, 2010 | TruTech LMD-5702RT Portable DVD Player
Red then green blinking lights.
push power on at button (no need to hold button)and press proceed button for 2 secounds at the same time you turn on power and it should reset.
Dec 24, 2007 | NEC PlasmaSync 50MP1 50 in. Television
Need help with TV
Must be a problem with the back light circuit. This not a repair for the amature repair person or handyperson seek out a pro as there are no user replaceable parts inside this unit. Good Luck
Aug 04, 2006 | Akai LCT2660 26 in. HD-Ready LCD...
HP iPAQ HX2700 Pocket PC Logo
24 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
