Question about Philips GoGear HDD6330 MP3 Player
Philips 6330 go gear froze then lost all the songs can they be re
My 6330 was in use when it froze. when i tried to reboot (which hapens often) ALL THE SONGS DISAPPEARED. CAN THEY BE RECOVERED
  • welovefm2 Jan 26, 2009
    my philips hdd6330 mp3 playaer will not display or play songs i had loaaded on it. the devise manager will not recognize it even after i uninstalled and reinstalled the software.the songs show up on the go gear screen of my rhapsody site and shows 23.9 gb use nothing shows on the device. everything else on the device works . just cant get to my songs
    President:
  • 2,559 Answers
Your songs are still there.
Try these 2 solutions.
  1. Turn the player off,Hold the volume up and the power while you plug it into the usb on the computer and hold those buttons until a box opens and says that you are in the tool box.then follow directions in the tool box.(If this didn't open the tool box,go to the next option to open)
  2. open my computer,open your hard drive,open program file,open philips,open toolbox,
when the toolbox opens,it will tell you how to do step one above for your player,(If it doesn't open on the screen it will appear by the clock,just double click to open)
Posted on Jan 26, 2009
    Scholar:
  • 191 Answers
Download this software and try to recover the data. or try this link also. If the data won't recover then it is better to avoid this problem again by following the below steps.
  • Check if the firmware on your player is the latest one.always updating your player’s firmware to the latest version can reducethe chance of future freezing or hang up.
  • Do a soft reset by inserting a small pin or unfolded paperclip into the reset hole.
Note: Your songs and data will not be lost or corrupted either of the above method.
If both of them don't work, you may have to use the Device Manager to recover your player.
  1. If you have not already installed the Device Manager,follow the on screen instructions to install the Device Manager fromthe installation CD or download the latest version of the DeviceManager application from http://www.philips.com/support.
  2. Makesure all other applications Windows Media Player or Windows Explorerthat access the device are closed or else Device Manager will notrecognize the device. Launch the Device Manager at Start->Programs->Philips Device Manager on your PC. Select the REPAIR tab on the dialogue box.
  3. Poweroff the player. Press and hold the volume increasing key and thenconnect it to the PC until you are prompted to release the key.
  4. Select the device name and then click OK and REPAIR. IMPORTANT: All music & content of your device will be erased once the Player is repaired.
  5. Once the repair is complete a dialogue box will pop up; click OK and unplug the Player from the computer.
  6. TheDevice Manager will close automatically once the success message isdisplayed. Close all opened application and then unplug your player.
  7. Once the player is disconnected from the computer, the display will show Firmware Upgrading for a couple of seconds and then start up as usual.
  • 6,487 Answers
This is a corrupted firmware which is the operating software of your mp3 player and if its not detected by your computer now, try first powering off the unit for about 5 minutes and if possible to remove the battery that will be good tor refresh the unit then after that hopefully your computer will recognize and if its recognize by the computer you can now check the manufacturer web site for any firmware update for this unit to fix the problem...
  • 3,037 Answers
You have the songs on your computer still correct? If so, go into the menu on the device and reset the device to default settings and then the computer should again recognize the device and you should be able to redownload the files onto the device.
bestdarngood
  • 916 Answers
This error is caused by a defective hard disk. You will need to call the manufacturer to have it repaired.
  • Philips Master
  • 19,396 Answers
There are two possibilities.
1 songs were not saved on default folder, and unit has done reset, like when you push in the reset button at the bottom with a pin.
In this case it resets all settings and files stay there, but in a different folder.
Connect the Go Gear to a computer, and see if you can find the file , if not the disk may have been formatted.
2 The disk had been formatted , when this happen there is no way , not even with recovery software.
3 the disk is defectifve and the rgo gear cannot read anything but an empty folder.
This is the most likely, connect it to a computer and use a diagnostic softare to test the disk. .
  • Ginko
    Ginko Jan 26, 2009
    push in the reset pinhole button at the bottom with a pin.
    In this case it resets all settings and files stay there untouched, if it says 23 Gb in use, then the files are still there and only the system is bad.
    The pinhole resets system settings.
    Genius:
  • 1,550 Answers
You need to connect your mp3 player to pc and use the software from the link below to recover it .
http://www.softforall.com/Utilities/Backup/Data_Doctor_Recovery_Removable_Drive09020728.htm
    President:
  • 1,990 Answers
Welcome to Fixya! Try Plugging it into the USB on your PC and then go to Start Menu and Search for the Removable Disk. It should be at the Bottom on the Drop Down list under Search. You should be able to look at Every File in the Player and Send the Songs back to your PC to Reload where you want them. Let me Know!
  • Philips Master
  • 13,433 Answers
The disk was format and the space was marked free.
try the filescavenger demo and see if it can recover the files for you
http://www.quetek.com/prod02.htm
let me know if you need further assistance.
My MP3 Go gear vibe freezes up when updating files
try to reboot it using the disk come with philip 4 gb gogear flash or download from internet
Mar 08, 2011 | Philips GoGear Flash MP3 Player
My go gear froze..."the music was playing and then it stop and froze on the song
try pressing the reset button it will NOT wipe off all of your music
Apr 22, 2010 | Philips GOGEAR SA6045 MP3 Player
I went to trun my friends Philips GoGear HDD 1830 mp3 player on and it just froze, is there away I can fix it with out loseing any song's, pic's and other stuff that is already on there? please help......
try plugging it into a charger or usb port. this usually causes them to reset. unless there is a serious problem with the memory you should have to worry about lost data
Mar 08, 2010 | Philips GoGear HDD1830 MP3 Player
Licence Problem with Philips GoGear 2GB
try removing the dmr on the files heres a site with a freeware program to do this i havent tested it yet but try it www.downloadatoz.com/...drm.../drm-removal-freeware.html
Sep 25, 2009 | Philips GoGear SA3125/37 MP3 Player
My gogear is frozen. One song ended and before the next one started it froze and it has been like this for several hours. It doesn't respond to any of teh buttons being pushed
Try doing a soft reset. 1. Press and hold the Power on/off key and the volume + key for a couple of seconds. 2. Then switch on the GoGear using the Power on/off key. Note: Your songs and data will not be lost or corrupted by a soft reset. Update your players firmware to the latest version to reduce the chance of future hang-ups. (http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=NZ&slg=ENG&cat=MP3_PLAYERS_CA&sct=HDD_AUDIO_JUKEBOX_SU&session=20090608204052_67.190.4.112&grp=PORTABLE_ENTERTAINMENT_GR&ctn=HDD6320/01&mid=Link_Software&hlt=Link_Software)
Jun 09, 2009 | Philips GoGear HDD1830 MP3 Player
My phillips go gear froze in the middle of song. will not shut off.
Pull the battery or unplug for 5 minutes. this will reset the core. if the device remains in the frozen state, you will need to replace the core micro board.
May 22, 2009 | Philips Audio Players & Recorders
I tried to sync/download music license (was getting message "drm license needed"), and it froze, can't turn off. HELP?????
There is a small reset button on the bottom but you need something like a needle to press it. Also , I have found when I open up my go gear from my computer and drag and drop songs and videos it has not had any problems.
Please take time to rate
May 13, 2009 | Philips GoGear SA3125/37 MP3 Player
My philips music device froze on me. i was trying to put music on and when i ejected it it froze in my music. i cant turn it off, change the song, or listen to music. please help!
There is a reset button.
If it freezes again after reset, go to Philips website, get the upgraded version of the Philips Device Manager and run the Update tab in Philips Device Manager.
-Tha Mp3 Doctor
Feb 18, 2009 | Philips SA3025/37 Flash MP3 Player
My go gear is froze and when I restarted it it was froze still
This have been my sons second mp3 player in less then 1 month. His mp3 players keeps freezing up and I have tried every item available. This is really frustrating. I purchased this for a Christmas present and it has not work for a month straight.
Jan 27, 2009 | Philips GoGear SA178 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
29 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
