Question about JVC HD-56G787 Television
JVC 56' HD
Lamp warning came up and tv went off. power and lamp button blinking,, changed out the light, tv working fine, turned off for the night and got up next morning and it was doing the same thing(blinking) and would not come on. We was told that it was a default in the lamp... went and bought another lamp and worked fine. turned it off before we went to bed and got up this a.m. and it is doing the same thing(will not come on and lamp and power button blinking at the same time... HELP!
  • 3,037 Answers
Hi vannah18
These lights blinking are a error code like you said. Only this error code you are getting can be three different problems and not just the lamp itself which I would think is good.
1. the lamp door is not on the tv
2. the lamp did not fire because the lamp is bad.
3.the lamp did not fire because the ballast is bad.
With out some testing we cannot be sure. but if the lamp door is on the tv then odds are your ballast is bad and should be replaced.
Thank you for using Fixya and good luck
bestdarngood
Posted on Jan 25, 2009
  • 535 Answers
Its problem due to lickey capictor u have find the ckt bord a licky capcitor then u need to replace it
  • 10,594 Answers
Please double check does Lamp is fixed and lamp cover is closed properly.
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Jvc 56fn97 wont do anything but blink blue on power button
Reseat the lamp again, and make sure that the lamp door is completly closed and screwed shut. There are safety switches that keep the set from turning on if all is not secure. If this does not help, you either bought a defective lamp, or your ballast is the problem.
May 01, 2012 | JVC HD-56FN97 56" Television
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
Have jvc model HD56G886. heard a pop..picture went off...blue light over on/off switch blinks quikly. Lamp go bad?
lamp is burned out, reorder one online and install-cheap and easy, the lamp will come with instuctions
Jan 15, 2010 | JVC HD-56G886 56" Rear Projection HDTV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
J.v.c. big screen tv 56-58 inch
my jvc big scrreen worked just fine last night and this am i turned it on and the color is greena and red with double vision can you help
May 25, 2008 | Televison & Video
JVC HD-56G787 Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
