Question about HP Pavilion zt1170 Notebook
Scroll pad wont let me scroll by touch
I have a compaq presario and the scroll pad wont work when i try to use the vertical scroll by touch. Thank you for your help.
Position of scroll lock
Reinstall your driver for touch pad. In certain cases charger does not work properly and create problem for touch pad.
In case of any future issue inbox me.
Nov 28, 2013 | HEWLETT-PACKARD Compaq Presario CQ62210US...
My keyboard and touch pad compaq presario cq40 not working i try to reinstall keyboard and touch pad but it still not working ,and then i remove to put new keyboard but it still not working at all..... so...
You tried to reinstall the keyboard and touchpad hardware parts? Have you had ANY damage? Spill? OS upgrade? If you replaced the hardware is the ribbon cables connect properly?
Apr 19, 2013 | Compaq Presario CQ40 Series Laptop Charger...
Hi, I have a Compaq Presario CQ56 & the scroll area on my mouse pad isn't working. Can this area be turned off and if so, is there a way to turn it back on/unlock it?
The scroll pad on the touch pad needs a particular driver Synaptics Pointing Device Driver. This will actually run at the startup after installed which will activate the functionality of scroll on the touch pad. You can also actually turn this function on and off so this is a friendly user.
If you do not have that driver that comes with your laptop you can go here:
http://www.compaq.com/cpq-country/cpq_support.html
or here
http://www.synaptics.com/support/drivers
Good day.
Jun 19, 2011 | Compaq Presario CQ56-115DX Laptop
Scroll on mouse pad not working
try to re install the driver of mouse pad touch pad.. install the oreiginal
Jun 28, 2010 | HP Compaq Presario CQ61420us Notebook
Vertical scrolling not working
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
May 22, 2009 | Compaq Presario CQ60-220US PC Laptop
Touch pad
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Hope that helps :)
Mar 13, 2009 | HP Compaq Presario 2200 Notebook
Scroll sections on mousepad not working
almost certainly this means that the drivers for the touchpad have reverted to the windows generic drivers. Try the driver from Compaq here. Sadly, without knowing the OS and exact model number of the laptop I can't be more specific on the link than that. The exact model of the laptop is usually printed on a sticker on the bottom.
Nov 29, 2008 | Compaq (153515-001) Touch Pad
HP Pavilion zt1170 Notebook Logo
162 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
