Question about MGA Entertainment Hot Hoops refresh
Need replacement balls for hot hoops game - MGA Entertainment Hot Hoops refresh
I need replacement balls for the Hot Hoops. Where can I purchase them?
Does not look like the balls are available separately. You would have to purchase another entire unit - about $30. Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Mar 23, 2015 | MGA Entertainment Hot Hoops refresh
Learning hoops replacement balls
Hi, I found them on amazon, click here and take a look: Amazon com POOF Slinky 875 POOF 4 Inch Pro Mini Foam Basketball Assorted... I hope this was helpful. Cheers
Jan 11, 2014 | LeapFrog Leap Frog Learning Hoops...
How to install Hampton bay fan #CF 004-52 on a slanted ceiling
I'm an electrician and can help you with your question.
Most (if not all ceiling fans) are designed to hang from most ceilings - flat or angled. This is done through the use of a molded plastic ball secured to the downrod of the fan assembly, that will allow the fan to "self-level" in the hanger
A special "hoop like" hanger is secured to the fan rated electrical box that allows the fan to hang straight down - providing that your ceiling isn't at a real freakish angle - all by itself. The only other thing to watch for is the blades. This is especially true if the new fan has larger blades or a shorter downrod than the old fan. Make sure that the fan blades will clear the ceiling (and enything else for that matter) when running. Otherwise, you will need to use a longer downrod to allow the fan to hang a little lower. Make sure it is not too low to prevent it from striking people walking below it.
Review the installation manual and check out the support "hoop" for the electrical box and the downrod with the plastic ball on the end (may require assembly of the ball to the downrod). You can install the support hoop and hang the downrod to make sure you understand how it works without assembling the rest of the fan.
If you have any problems, you should contact Home Depot (Hampton Bay is a Home Depot house brand) for support.
Mar 28, 2013 | Hampton Bay 04345 Cruiser Ceiling Fan
How to make pioner toys
Stick and Hoop Pioneer children could play this game while they walked across the plains or on their way to school. Find a smooth stick, about 8 inches long. Tie a piece of yarn around one end of the stick. At the other end, tie a solid round hoop. This could be the ring of a jam jar, a key chain ring or a thin plastic toy ring. The smaller the hoop, the more difficult the game. When the stick and hoop are assembled, try to flip the hoop into the air and catch it on the stick. It's much harder than it looks. If the child masters a larger hoop, substitute it for a smaller one.
Apr 16, 2012 | Car Audio & Video
Sportcraft
Last time Arcade Hoops replacement parts I bought from amazon. Take a look on this link Amazon com Arcade Hoops replacement. I hope this was helpful. cheers
Mar 13, 2012 | Sportcraft Arcade Hoops With Electronic...
How can I get replacement basket balls for hot hoops? I have looked everwhere! Please help! Thanks
I wrote to the company and this was the response:
Thank you for contacting MGA Entertainment
We are sorry. The product is discontinued and replacement parts are no longer available. We can only
recommend checking second hand sources such as ebay or local hobby stores. We
do apologize for any inconvenience.
Thank You,
MGA
Entertainment
Dec 04, 2010 | MGA Entertainment Toys
Need replacement balls for a Huffy electronic
I have found the number for Huffy. You should be able to see if they have replacement balls for your electronic basketball game.
U.S. Customer Service
Email: service@huffysports.com
Phone: 1-262-820-3440
Phone: 1-800-558-5234
Fax: 1-262-820-6757
Thank you, hope this helps. Please let me know.
Apr 30, 2010 | Huffy Dual Electronic Basketball Game
Wii Fit Hula Hoop does not register on rotating to the right
you rotate left your hula hoop same your body and you move the hula hoop with your body
Feb 03, 2009 | Nintendo Wii Console
Replacment 7" basketballs
http://www.amazon.com/Voit-Voit%C2%AE-Super-Mini-Basketball-EA/dp/B001285TW8
One reviewer even specifically notes that he bought them for your same game.
Jan 04, 2009 | Park and Sun Sports PS-FAH Fold-A-Hoop...
Wii Fit Hula Hoop Game
try standing as far back as u can, then jump and then do twenty jumping jacks.
Nov 24, 2008 | Nintendo Wii Console
MGA Entertainment Hot Hoops refresh Logo
425 people viewed this question
Top MGA Entertainment Toys Experts
ray gallant
Are you a MGA Entertainment Toy Expert? Answer questions, earn points and help others
