Need schematic for fbt maxx 2a - Televison & Video
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Posted on Apr 10, 2010
I need to find out which potentiometer is on the Mid range for a FBT Maxx 6a speaker
The value of the pot is found on the side of the cover. Look for numbers like 10k, 250k 100k. That is the value of the resistance of the part. Any brand of replacement pot will work as long as the resistance number is the same on the new part
Oct 12, 2017 | The Audio Players & Recorders
2006 Malibu maxx, which fuse controls the cruise control?
The underhood fuse block contains 30A IBCM (R/C) fuse 21 and 50A IBCM2 fuse 25. The body control module (BCM) contains the 2A RUN/CRANK fuse and the 10A interior lights fuse. All four of these fuses affect the cruise control.
Sep 13, 2012 | Cars & Trucks
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
Im having problems with my 05 maxx..... electrical???
I would get all the electrical schematics and then look for problems like blown fuses affecting the areas you are describing. Then systematically troubleshoot the wiring. Simple.
Now, I am looking for the mentioned schematics on the web. I just bought (2010-01-28) a 2005 Malibu Maxx, and can't wait to have it ready for pickup in 2 days...
Jan 09, 2010 | 2005 Chevrolet Malibu Maxx
Samsung CT-29M6P H.O.T. repeated failure
Hey did you check the B+ requirements for the HOT? It is commonly be around 110 volts DC. And commonly HOT should be test with the FBT connected.
From your observation it is most likely the FBT has some short in primary, also check other component after FBT commonly some medium size diode if it is getting shorted.
Hope this additional input helps you.
Apr 08, 2009 | Televison & Video
F36650 36
Hi again,
Appreciate the direct "Ask Me"
To your unit RCA F36650/CHASSIS # ATC113CA1, I posted replies to your original problem here.
FBT would be the FlyBack Transformer or Line OutPut Transformer (LOPT).A ring test is check for the FBT out of circuit using an instrumentthat sends pulses to the FBT's primary circuit. Thereafter a comparatorcircuitry checks the number of damped oscillations or 'rings' producedand determines if the primary is good or not.
Incidentally, it could also be the power supply unit (PSU). You could verify by doing the check on the HOT or lifting the supply to the main B+ going to the FBT and trying it. It the PSU powers up and the light lits as well as the sound comes up, the PSU is good and HOT/FBT is suspect.
You might be better off getting hold of a service manual or at least a schematic diagram.
Incidentally, 13 years is a rather long time in electronics with the technology changing at such a fast pace. 13 years ago we still have a few Betamax and laserdisc players especially those by Pioneer.
Cheers.
Jan 04, 2009 | Televison & Video
Need to replace Flyback Transformer
FBT just solders in and out you do not have to have sams which now comes on disk to replace Fly.You need part # to FBT there is only 2 wires to hook back up .
Dec 22, 2008 | RCA Scenium D40W20 40" Rear Projection...
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
