Emergency heat comes on everytime heat pump starts UPKA025JAS
My Ruud heat pump has a electick strip heater in the duct. Everytime the heatpum comes on so does the emergency heat. The wiring diagrams that I have been able to find do not show the correct wiring for a proper thermostat hook up. Does someone know how this shold be connected??
  • 1 more comment
  • coss985 Jan 31, 2009
    The t-stat is a heat pump type it is a Simple Comfort # 2200. It is 5 years old and has never been touched. The terminal blocks are as follows:
    B  O  W2  G  E  Y1  Y2
    The "B" has a blue wire
    The "O" is empty
    The "W2" has a white wire
    The "G" has a green wire
    The "Y1" has a yellow wire
    The "Y2" has nothing
    There is an Orange wire that is cut clean and does not look like it was ever attached.
    The wiring diagram that came with the T-Stat is missing but from what I can see on line none of that makes sense.
    I will say that I just moved into this house "it's my sister and i am down from Vermont helping her put her affairs in order (enough said) so I do not know the history but she says it has not been touched for several years. There is no way for me to tell how long the emergency heat has been coming on everytime the system calls for heat but I can not believe it is suppose to work that way? The Ruud site , unless I am looking in the wrong place, just plain SUCKS.  I know enough to be dangerous but I don't want to just start ripping out wires although if I new which one ran the emergency heat I would disconnect that as it is Florida after all!!!
    I appreciate any and all offers for help. Thank you so much for your help offered so far.
  • mopar440man May 11, 2010
    what are your wire colors at the t-stat and control board or heat contactor do you have a heat pump tstat it will have a b/o term
  • Ken Bledsoe May 11, 2010
    Has someone did anything to thermostat? Or did problem just begin after working for the last few months?
Most heat pumps do use the heat strip when they start untill the compressor gets the heat going. This keeps the air coming out of your vents warm as the system is ramping up.
Posted on Feb 24, 2009
  • 146 Answers
  • 306 Answers
Your white wire is controlling the heat for your strips. while the blue is for the heat pump side of heat. But if you disconnect the white be sure to wrap tape around it so it doesn't contact any other wire. Would cause a short and you would loose a transformer.
Posted on Jan 31, 2009
I have a 5-ton Nordyne heat pump. The compressor has quit working. How can I get the emergency heat strips to come on using emergency heat on the thermostat.
Your thermostat should have an emergency heat setting. Putting the thermostat in that position should make the electric heat strips only work and keep the compressor from coming on. If your thermostat doesn't have an emergency heat selection disconnect the compressor outside at the power source. Turn the thermostat 5 degrees Above the Rim temperature the electric heat strips should come on.
Jan 02, 2018 | Heating & Cooling
Honeywell troubleshooting
Emergency heat is the setting that shows that your heat strips are activated. Sometimes people do not wire up the heat strips at all as the use a great deal more power than the normal heat pump uses. The problem is that a heat pump comes to a point where it is not efficient at about 28 degrees and this is where you need the heat strips or if you want to heat the house quickly which a heat pump will not do. Heat strips are located in the ductwork and act like a space heater. A H/A tech is probably needed to check this stuff out for you.
Nov 15, 2013 | Cars & Trucks
How to hookup Auxiliary heat (and/or use an extra wire at the thermostat)
They don't always use the correct wire colors,if it is labeled w it is for your strip heat,shouldn't hurt to hook it up,most likely they used it for the strip heat,most heat pumps are wired to turn on your strip heat when the heatpump is in defrost mode and it is controlled by the heat pump,you can hook this to the emerg. heat or w2 :)
Mar 08, 2013 | Ruud Heating & Cooling
What if your unit is not turning on....but the inside unit is still heating..
Most heat pump systems utilize electric strip heaters as back-up and emergency heat. This will allow the system to continue to produce heat in the event of heat pump failure. If you are having problems getting your heat pump to turn on, you might have a blown line voltage fuse, a tripped circuit breaker, or a high pressure switch tripped. The high pressure switch on a Rheem or Ruud unit is a red button located near the service valves at the outdoor unit. Try pushing the button to reset. Check your indoor air filter and replace as necessary.
I hope you find this helpful. If you continue to experience problems, please let us know and we will dig deeper to help you. :-)
Mar 30, 2010 | Ruud UBHC Air Conditioner
The cold air return is bringing cold air into the house
The Cold Air Return is really the Return Air. The Purpose of the Return
air duct is to pull the cooled or heated air back to the furnace. It then
filters the air before getting cooled or heated again.
This is what controls the thermostat, which starts and stops the unit. In
the end this is how your air stays conditioned. In some states it is
required by law that a 4-6inch fresh air vent be tied into the return air
duct. Everytime the furnace fan comes on, it pulls in fresh air from
the outdoors.
Feb 10, 2010 | Dayton Gas Furnace Heater
New heat pump system freezing, questioning wiring.
W1 and E on stat need tied together. When W1 comes on wire where all heat elements come on. On the outside unit defrost board set the 45-60-90 to 45 and see if that takes care of the frost problem.
Jan 03, 2010 | Heating & Cooling
What's the difference between EM HEAT and AUX HEAT?
Sorry, neither of these answers are completely correct.
You have a heat pump (or the wrong thermostat). Let's assume you have a heat pump.
In air conditioning mode, it works like every air conditioner you have ever had, but...
In heat mode, it reverses its operation. Have you ever felt the air coming out of the outdoor unit of your A/C unit? It's hot, isn't it. And the air coming out of the indoor unit (out of the registers) is cold. Now for a heat pump to produce heat it simply runs the air conditioner in reverse and the heat comes out in the house and the cold is released outside. Neat, huh!
Here's the problem with heat pumps...when it is really cold outside the heat pump can't produce enough heat to heat your home. So it has an additional heat source called "Auxiliary Heat". This heat comes on automatically when the house doesn't get warm enough. The source of this heat is based on the region of the country you are in. North/Northeast generally have oil heat, other regions have gas, and still others have to use electricity to heat. In Texas, we usually use electricity as the supplementary heat on heat pumps. VERY EXPENSIVE!
Now the "Emergency Heat"...this is exactly as stated in Solution #2. This is manually turned on by YOU at the thermostat when your heat pump fails. This turns on the auxilliary heaters and turns off the heat pump (remember, the reverse air conditioner). Again, this can be quite expensive to run if your heat source uses electricity! Gas and oil may be cheaper. The emergency heat is only designed (normally) to keep the house livable (not comfortable) until the Heating Tech can get out to you and fix your heat pump.
Something else you should know. It is normal for a heat pump's outdoor coil to frost up during heating mode. It will detect this and go into DEFROST mode and melt the frost off the coil. While it is doing this, it will turn on the auxilliary heater to keep the air blowing in the house at a reasonable "warm" temperature, but it will not be as hot as normal. In fact, heat pumps produce a lower temperature heat than traditional heaters. So the air may feel cooler during heating than you are use to anyway. This is normal and is not a sign of a problem.
So what do you do: Set your thermostat to the temperature you want and set the controls for HEAT/COOL and FAN-AUTO/ON and leave the EMERG HEAT off unless your heat pump breaks.
As always, keep your filters clean and your outdoor unit's coils clean and free of debris.
Hope this explains your question for you!
Oct 16, 2009 | Ruud Central System Air Conditioner
Smell when unit comes on with heat
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
Jan 19, 2009 | Ruud Matching Split Air Conditioner
Outside unit clicks while thermostat auxiliary light flashes
Sounds like the compressor starting relay or capacitor is defective. When the compressor could not start, the electric heat came on to satisfy the heat requirement and causing the emergency heat light to come on at the thermostat. This light warns you that electric heaters are energized. And they use a LOT of electricity! Call a different company for service. And do it soon.
Nov 16, 2008 | Ruud Handler Air Conditioner
What you are talking about I think are the strip heaters in the Air Handler this must be a Heat Pump system right??? If so please check your thermostat and make sure it is not in EMRGY HEAT mode.. One other note there is a 2 stage bulb system inside the stat if it is too cold outside and the heatpump on its own cant keep up with the call for heat the 2nd bulb closes and turns on the heater as a supplumnetal heat also these will come on or should come on when the unit goes into defrost.. plz let me know what it is you are trying to test and i can walk you thru it.. Also need a model # off the A/H to get a Wiring diagram
Feb 03, 2008 | Ruud Handler Air Conditioner
Heating & Cooling Logo
450 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
