Question about Craig Televison & Video
How to hook up dvd player with red blue and green connectors to direct tv box with red yellow and white connectors
Model #CVD505
  • Craig Master
  • 5,342 Answers
The Red Blue And Green are for things like projectors they send out the 3 colours to make up the TV screen.
The Red and White connectors are right and left audio the yellow is video.
I don't think you can connect these two together. So unless the box has a scart socket and the DVD player one also you are stuck.
If there's a problem caused by a shortage of scart sockets, then can I suggest a Scart Switching Box from places such as Amazon, shown below:
how to hook up dvd player with red blue and green  - 1_18_2013_5_39_17_pm.jpg
Posted on Jan 18, 2013
SOURCE: hooking up the dvd player to the new tv
I HAD SAME PROBLEM. WHEN I WENT TO THE SETUP ON SCREEN MENU (#5) IT SHOWS THE DEFAULT FOR "VIDEO OUT" SHOULD BE "COMPONENT". MINE WAS ON "S-VIDEO". I CHANGED IT TO "COMPONENT" AND IT WORKED FINE.
Posted on Feb 16, 2008
  • 152 Answers
SOURCE: DVD and the new converter box
Lorrie47, Need more info to help you. YRU trying to connect any A//V cables to the HDConverterbox to your DVD player? Can you plug the DVD player into the widescreen HDTVset or do you have old NTSC TV set like I do? I haven't even been to Circuit City, Sam's Club, or BestBuy to see what kinds of connectors are on those HD Tuner/Converter Boxes. Is the converter box u have equipted w/yellow(video), red(right), White(left) analog signal in's and out's? If the new HDTVconverter box has BASEBAND in's and out's then the installation/owners manual should have directions for their proper use. In any case you need to be more specific on what you are trying to accomplish. Tell me, does TV set stay on channel 3 , and never ever changed to chan22 or 51 or 8. Its always set to ch3?
Is it possible that maybe TV set has baseband (yellow,red,white) in's and out's on rear of cabinet? Now here are some rules to follow. Outputs must go to inputs. and colors must match. I assume that the HDTV tuner/converter box has a infrared remote control to do channel change and vol/up/dn and possiblly other things like switching of sources. does the manual say anything about AUX A/V inputs that can be used? Hpoe this has been of some use to U. I'm Louie12fix can be emailed @ this:
lmistyrel @ aol.com north of Chicago
Posted on Jan 13, 2009
SOURCE: how do i hook dvd player to tv..i know its probably simple
The yellow and white cables hook into your tv inputs
Posted on Jan 19, 2009
JULIANFIX
  • 975 Answers
SOURCE: I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
Posted on May 08, 2009
  • 5339 Answers
SOURCE: how do you hook up this dvd player to the tv. the
The DVD player has component video as well as the S-video and RCA video and two RCA audio outputs.
If your player is the same as my picture, the component video jacks are in a horizontal line at the top of the back of the player. The white and red audio jacks are in a vertical line to the left. The yellow video out jack is in the second line just below the component video jacks (in a line with the coax port, the S-video port is in between the coax and the RCA video out). (The white jack is at the top left of the connections block, red below that, and yellow to the right of the red.)
I hope this helps.
Posted on May 29, 2010
How do I hook up this DVD player to my 60 inch Westinghouse model #VR-6090Z ?
If your DVD player has HDMI, use it. If not, you'll need to buy a cord for it. Look on the back of the TV and the back of the DVD player. There should be colored connectors on each one. On the TV, it will be an input. On the DVD player, it'll be an output. There will be either 3 connectors or 5 connectors on the TV and DVD player. You'll need a cord with either 3 connectors on each end (red, white, yellow), or one with 5 (red, white, blue, green, red). Once you figure out which cord you'll need, buy it from any store that sells TVs and hook it up. The link below has pictures
Video Connectors Tutorial Hardware Secrets
Feb 02, 2015 | Westinghouse Televison & Video
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
How to watch dvds with a converter box connected
You should connect the dvd player directly to the television and not the converter box.
DVD player may have red, white, (audio) and yellow (video) connections or it will have the red and white connections for audio and then red green blue for video.
Connection depends on the television inputs.
i hope this helps, if not send me another question I will walk you through it.
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook up
red to red, white to white, s video to s video, composite to composite...dude what are you trying to do?
May 25, 2008 | Durabrand STS92 System
Hooking up the dvd player to the new tv
No you don't need them. The red, blue, green wires are component cables for HD.
Jan 26, 2008 | GPX D1816 DVD Player
Dvd player only plays in b&w, and connectors dont seem to match up with tv
I had this problem too. I had to use the cables that have red white and yellow and the back of the dvd player had red whit yellow but also had another set of red blue and green. I had to hook white to white,yellow to green and red to blue and it fixed it. Hope this helps
Sep 09, 2007 | Televison & Video
Televison & Video Logo
120 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
