Question about Onkyo Ht-rc330 5.1-channel Home Theater Receiver
How do we connect our system using a Shaw PVR
    New Friend:
  • 3 Answers
Do you have a optical/coaxial input on your system? Eg: cable, TV.I use a optical input on my Yamaha ( cable, satellite ). Look to see if there is a optical/coaxial output on your pvr, there should be. Use ether the optical or coaxial output from your pvr and connect it to the cable (satellite ) optical/coaxial input on your receiver. The manual that came with your Shaw PVR should explain how. You will get 5.1 surround if available on certain channels.I prefer optical over coaxial myself, but they both work well.If you don't have optical/coaxial inputs on your receiver, you will have to use RCA cables, analogue out on cable box, to tape input or aux on your receiver. You will not get surround sound, just stereo. But it's better than nothing.
Posted on Jan 19, 2013
SOURCE:
How to pvr a future show on shaw?
Take your Shaw remote.
Press the GUIDE button.
Use the up/down buttons to select the channel for the program.
Use the RIGHT button to move forward in time until you see the name of the desired program.
Press the INFO button.
Press the RIGHT button, to highlight the "red" RECORD button.
Press OK.
Apr 02, 2014 | Televison & Video
I'm a customer of HDPVR with Shaw services! I have a Shaw Remote and I can't record or access previous recordings ! Other aspects of the Remote works (volume channels )How do I return to the services I pay...
Disconnect the PVR from the electrical power.
Reconnect it.
Wait 10 minutes, while it "reloads" its programming.
Press LIST. If your recordings are not showing up,
it's possible that the disk-drive inside the PVR has failed.
Telephone Shaw to get free technical support.
Jan 12, 2014 | Televison & Video
Shaw pvr expander not working
Take your Shaw remote control.
Press SETTINGS.
Use the LEFT/RIGHT keys to highlight PVR.
Click OK.
Use the LEFT/RIGHT/UP/DOWN keys to highlight PVR HISTORY.
Click OK.
Scroll through the entries, looking for any "hardware failed" or "hardware error" messages -- finding any implies a failing disk-drive inside the Expander.
Need more help? Telephone Shaw, and ask for "technical support" for TV/PVR.
Jul 21, 2012 | Motorola Televison & Video
How to open up remote shaw pvr controller
Why would you want to "open" it?
If it is not working, take it to the nearest Shaw retail store.
Shaw will replace it, no questions asked.
Apr 15, 2012 | Televison & Video
Can't see image with shaw pvr on toshiba 32hl57
I presume you followed the instructions in the TV manual during hookup and did not hook up with the units powered up and did select the correct input with the remote?
If you have another unit that uses HDMI try a direct hookup with it to see if the HDMI input is working.
HDMI units do not like being hooked up when units involved are powered up and on--seen more than a few where this was the problem and it is worth a try if the Owner Manual does not help you.
Apr 10, 2012 | Toshiba Televison & Video
Our shaw pvr recording symbols have now turned into snowflake shapes
Disconnect the AC power from the PVR.
Reconnect it.
Wait a few minutes for the device to "call home" to completely reset itself.
Then, press LIST to show the recordings, instead of those "asterisk" characters.
Failing that, telephone Shaw to get free technical support.
Mar 18, 2012 | Televison & Video
Soyo tv code for shaw pvr remote
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Jul 31, 2011 | Soyo SYTPT3727AB Television
Sound drop with Shaw pvr box with hdmi. How do
This is a very common problem with no real solution. If your TV can be programmed to accept separate audio from HDMI video on the same input, you can feed the audio through standard RCA cables. Unfortunately most TV's do not allow this. Alternatively run them into a stereo receiver. Buying high end HDMI cables will not help. Most people I know with this issue have bit the bullet & just used component video instead. The difference in quality is minimal.
Apr 25, 2010 | Arris DCT6200 DTV Receiver
Our Shaw cable box,Pace PVR,continously BLANKS out for no reason,When it does the guide on the tv says to be anounced for a minute or more! Changing the channel or hitting the channel guide up usually sets...
I have had the same problem and I spoke to a tech at one of the tv repair shops in Edmonton. He says it is a long standing generic problem that Shaw is having with the HDMI connection between the pvr and tv's, I have a pvr replaced twice and the problem remains. The last Shaw tech says to use component cables and it will solve the problem which I believe is an admission that the problem identified by the tv tech is true. Doesn't help with 4 hdmi.and two component inputs
Dec 30, 2009 | Televison & Video
Open Questions:
home theater setup- PC, HDTV, and Receiver I never post on these, but its been months and I can't take it anymore. I'm trying to use my plasma tv as the display for my PC, and use 5.1 sound with it through my receiver. However I don't use my PC for everything, so I'd like the smart TV to still work on its own and have audio from the receiver for that as well. Sounds simple, but trying to get things to work together is extremely difficult. I've found ways to rig it so that the speakers work, but its almost always just 2 channel audio and I'm looking for 5.1 surround. My PC hdmi output is HDMI 1.3 which doesn't support ARC so that isn't really an option. There's an alternate setup diagram for setting up without ARC that uses AV component cables, an optical, and an HDMI cable. This alternate setup actually worked but only for the sound, and now I can't get any video to come through. It looks like I may have to run the audio and video from the PC completely separate, but seriously??? In this day and age, I feel like that shouldn't be necessary and may be overlooking something. If I do run them separately, what would be the best way to do that? I also have a Creative 5.1 external sound card with optical out if I need to use that. Sorry if there isn't enough information in this post, there's a lot involved and I'm not sure what is relevant and what is redundant. I'd appreciate any help people can give me, each time I call support for a product, they blame another part of the system and say they can't help me. Please help, absolutely fed up with this thing.
Jun 26, 2013 | Onkyo Ht-rc330 5.1-channel Home Theater...
See all Onkyo Ht-rc330 5.1-channel Home Theater Receiver Questions
Onkyo Ht-rc330 5.1-channel Home Theater Receiver Logo
172 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
