I have a Country Firestar Gas Insert, Model #FFC 1, Pilot lights burners come on with remote, fire and pilot go out before reaching desired temp. ? Snap Switch?
Likt Pilot okay, burners come on when selected remote or manually okay, I hear a click and fire is out and pilot is out. I do not hear gas flowing into the fireplace at this time. Could it be the snap switch.
  • 6 Answers
SOURCE: Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Posted on Dec 02, 2008
  • 3313 Answers
SOURCE: intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Posted on Jan 02, 2010
  • 4 Answers
SOURCE: Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Posted on Mar 30, 2010
SOURCE: Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Posted on Apr 30, 2010
SOURCE: I have a Dyna-Glo unvented
MAKE SURE THERE IS AMPLE FRESH AIR IN THE ROOM, SOME MODELS ARE MADE TO NOT LIGHT IF THERE IS NOT ENOUGH FRESH AIR. RON G.
Posted on Dec 01, 2010
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
My pilot stays on on my propane furnace but will not light up
The Little Giant units use a Unitrol gas valve very similar to a water heater in the home. #1,urn the Unitrol gas valve to the "PILOT" position to ignite the pilot. Depress the plunger and hold it down then push the spark igniter button until you can see the pilot flame ignite.
You have a lit pilot so this is not a problem for you.
The pilot light stays on continuously by design.
Once the pilot flame is established, you then turn the on/off/pilot valve to the "ON" position and set the thermostat to the desired temperature range., it should then fire its main burner until the desired temperature is reached. Once the temperature is reached, the main burner will shut off and the heater will go into a standby mode with the pilot flame still burning.
If you have turned the pilot valve to on and set the temperature high, it should come on, if not a new gas valve is required, they can be very difficult to replace due to rust.and most cases require a new unit,
Mar 19, 2015 | Unitrol Propane Heater Valve - Little...
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
After oven reaches desired temperature, it has late ignition that turns off the pilot AND OVEN WILL NOT STAY ON.
Sounds like the pilot is mounted to far away from the burner. I have seen it happen before where the pilot has detached and the main burner will just keep pumping gas in until it hits the pilot flame and just flash flames and everything goes out.
Or it just could be a bad thermocouple that is going out all the time.
Mar 01, 2013 | Southbend S36D 36" 6 Burner Gas Range,...
When desired temp. is reached the water heater pilot goes off. I have replaced thermo-couple, it makes no difference. when water cools down, pilot must be re -lit manually. when it reaches desired...
Pilot will turn off if thermocouple is not seated fully in the flame, or if thermocouple is bad.
When replacing thermocouple, there are good videos on Utube.
Finger tighten new thermocouple then add 1/4 turn, so the insulator is not crushed.
Make sure new thermocouple is seated fully in pilot flame.
You might also need to clean out burner tubes:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Read manual for troubleshoot checklist, and recommended maintenance and advisories.
Cleaning the burner parts and combustion chamber should be done periodically.
I know it sounds old-hat to say read manual, except each model is slightly different with different recommendations.
Generic 22V40 manual on following link:
http://bostonheatingsupply.com/Rheem%20Res%20Gas%20Fury%20Water%20Heater.pdf
Page 23 has a few DIY steps that include replacing gas control thermostat.
New gas control can cost $60 - $120.
Also air in the gas line, low gas pressure, gas shut-off not fully open, pilot orifice clogged.
Problem may be combination of several factors, requiring clean out and replacement of parts.
If repairs cost more than $330, then buy and install new gas water heater from local box store:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 19, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
