Question about Dell UltraScan P1110 21" CRT Monitor
When i turn on my computer, it displays signal cable disconnect,and the restart switch doesnt function
  • 107 Answers
Try 2 check the cable if it is properly attached. try connect a different cable from your computer to your VGA
Posted on Jan 25, 2009
My computer starts up but the screen sa ys no signal
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
If its a 40 pin flat ribbon type it will be the first to fail.
Even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free.
Restart your computer then reinstall it this should activate found new hardware wizard
Check the VGA cable connection running from the computer to the monitor.
This cable must be completely inserted into both VGA connection ports, otherwise the video signal is not going to reach the display.
Disconnect the VGA cable from the computer and monitor, then look at the metal connectors on both ends.
If you are missing connection pins, the video signal is not going to transfer between hardware correctly.
To fix this problem, you must obtain a new VGA cable (at any computer or electronics store) to send the video signal.
Examine the power connection on the monitor.
If the monitor is not receiving power, it is not going to turn on.
Turn off the monitor for a few minutes, then power it back on.
Like other computer hardware, the monitor may not initially turn on correctly.
Move the mouse and press the "Enter" key on the computer keyboard.
If the computer is in sleep mode, the monitor is going to appear as if it does not have any display.
Hope this helps.
Nov 22, 2012 | E-Machines eMachines Desktop PC
Replace turn signal switch
Ensure lever is in center of off position.Disconnect negative battery cable. Disable airbag system. Remove steering wheel. Remove lower and upper column covers. Remove lock cylinder if necessary. Remove wiring harness strap. disconnect steering column electrical connectors. Disconnect turn-signal and multi-function switch Gray and Black connectors. Remove turn-signal and multi-function switch from vehicle.
Jun 05, 2011 | 1998 Chevrolet K1500
Cannot get my iomege z100PS to work....green and amber lights stay on with AC and computer cable connected or just with AC cable connected.
A signal display on the devices is indication of normal functionality. Attempt to restart the device, also restart the computer to attain reconfiguration settings.
Feb 06, 2011 | Iomega Z100P2 External ZIP Drive
My wireless mouse wont work
The wireless mouse functions with batteries. Snap open the location area at buttom of mouse to either check for misalligned batteries or dead batteries requiring replacement. Also, the wireless mouse has an adpater cable that is connected to the computer USB area from where signals are acquired during functionality. Make sure every connectable cables to the computer are firmly in place. Sometimes, the computer may require restarting to capture wireless establishments if an disconnections were encountered once computer was still on. Make sure every connectables are firmly in place, restart the computer for desired functionality. Also, a restart of the computer should diagnose the malfunction of mouse attachements. Improtant notes: A new wireless mouse may have required installation of softwares, opening the computer wireless devices estblihment area to regulate captions on the new setup priop to first acquisition of wireless mouse functionality. Good luck
Jan 11, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
The screen says no signal
If you have already verified the connection between your computer and the monitor you can try these steps to attempt to get an image on your monitor.
First, check your monitor for a button that says "source" or a button that has a square with an arrow pointing to the center. This will switch where your monitor looks for the signal.
A good rule to follow is if your monitor is connected to the computer by a cable with white ends, you should select "Digital", and if it is connected with a cable with blue ends, you should select "Analog" or "VGA". It is possible, but unlikely that your monitor is connected in any other way.
If these steps still do not work, follow these steps exactly:
  1. Press the windows logo key 220px-ctl_wndws_alt.jpg and "R" (This opens the "Run" window.
  2. Type this command: "shutdown /s /t 0" without the quotes. The shutdown command with the "/r" and "/t 0" switches tell shutdown to restart the computer at "time 0" which is immediately
  3. Wait for the computer to restart and it should automatically detect the correct display to use.
  4. If all else fails and you cannot get the display to connect, restart the computer and press "F8" until the computer comes up into safe mode. From there you can verify whether or not the monitor is actually functional, as driver incompatibility issues are not a problem when running in safe mode.
Nov 25, 2010 | Gateway FPD1975W 19" LCD Monitor
99 ford contour hazard flasher unit where is it
Flashers - REPLACEMENT
Turn Signal Flasher
(see Figure 1)
Fig. 1: The turn signal flasher is located on the multi-function switch in the steering column
  1. Disconnect the negative battery cable.
  2. Remove the upper and lower steering column shrouds.
  3. Pull the flasher from the back of the multi-function switch.
To install:
  1. Install a new flasher in the multi-function switch.
  2. Install the column shrouds.
  3. Connect the negative battery cable.
Hazard Warning Flasher
  2. Remove the knee bolster panel from the underside of the driver's side of the instrument panel.
  3. Grasp and pull the flasher from the connector located near the top of the steering column.
To install:
  1. Install a new flasher in the connector.
  2. Install the knee bolster panel.
Hope this help (remember comment and rated this).
Apr 02, 2010 | Ford Contour Cars & Trucks
My screen doesnt get a signal from the computer what could be wrong?
There could be three reasons for the same .
1. Loose signal cable: Check and reseat the VGA or DVI cable from the back of the system tower to the monitor.
2. Bad monitor : Disconnect the monitor cable from the back of the monitor check if the monitor displays anthing .
3. Bad video card : Try connecting an alternate monitor to check if the same is displaying anything on the screen.
Thanks for using Fixya
Proton
Jan 07, 2010 | Acer Aspire T310 PC Desktop
Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Nov 04, 2009 | Acer Aspire m5640 PC Desktop
Have tried connecting external monitor to aspire one,but get no signal .Works fine with the pc so is there something else I need to be doing
A few things to go through to attempt a signal--
1) when you connect the video cable are you hitting the Function (Fn) and F-key that corresponds to the video switch (Usually Fn key next to the Alt and Shift keys... and the F5 key at the top of your keyboard)
2) right-click anywhere on your desktop and select Properties. This should bring you to the display properties. go to the 'Settings' tab and see if it shows a second screen and attempt to activate it.
3) if that doesn't work your computer may require that you have the video cable plugged in before you turn it on. plug in the video cable and restart your computer.
Nov 22, 2008 | Acer Computers & Internet
Dell UltraScan P1110 21" CRT Monitor Logo
74 people viewed this question
Alun Cox
