SOURCE: Need instruction manual
Hi Guys,
Just found this - as i had the same problem!
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614D.pdf
Hope it helps!
SOURCE: I have a Cosco Scenera.. how do i keep it from
its kinda tough being 1993 cars not having the back latch. The only quick solution to keep it tipping side to side, try using a square piece of plywood big and wide enough that the seat will sit on the flat surface and you have to use the center seat belt making sure its tight and secure to make it work properly.
SOURCE: I took the cover off of the Cosco Scenera carseat
Go to www.coscojuvenile.com and download instructions or they will mail you some.
SOURCE: cant get cosco scenera model 22123 RMD car seat
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614E%20-%20US%20Scenera.pdf
Pages 40-46
SOURCE: how do we put belts
Here is the pic you requested. I am going to link to where I got it from as there was an issue (not a recall) with the harness getting cuts in it and I would like you to be aware of it. Being a parent I know how important those straps are. Hope this helps. http://www.car-seat.org/showthread.php?t=48028
