Question about Samsung WF203ANW Front Load Washer
SAmsung WF203 won't unlock and has code nd. Can I detach the drain pipe to check for blockage? Or what should I do?
4 Suggested Answers
  • 12 Answers
SOURCE: how do i fix the ND code where can i check for a
REMOVE POCET UNDERNEATH
Posted on Jul 26, 2010
  • 6277 Answers
SOURCE: i have a samsung front
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 19, 2011
  • 500 Answers
SOURCE: MY WF218ANB/XAA WON'T DRAIN BETWEEN WASH AND
Hi gumby323,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Posted on Sep 09, 2011
My samsung front end loader goes out of balance during the spin cycle. Is not making any noise. Flashes an "nd" code.
as far as I am aware the ND code means not draining would check your drain hose pipe or the filter could be blocked causing it not to drain properly while spinning
Oct 15, 2017 | Samsung Washing Machines
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain
ND means No Drain(ing). First check that the drain hose isn't kinked. Then, check to make sure the drain hose isn't pushed so far down into the standpipe that it is sealed closed. If it is too tight in the standpipe, it will create a siphoning effect. It has to sit freely but securely in the pipe.
May 30, 2012 | Samsung WF337AA Front Load Washer
How can you fix the nd code
The "nd" code indicates that your Maytag is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
May 26, 2012 | Maytag Washing Machines
Have a Maytag washer MAH8700AWW, I keep getting ND messag. Replaced water pump and machine still behave the same.
Hello, You may have not have had to replace the pump in all actuality. The ND error code can be caused by anything caught in the entire drain area which means from the port hole that comes out of the outter tub you would need to remove the hose that connects to this spot and then to the pump. Also you would remove the drain line after the pump as well and assure in both areas that there are no obstructions. If you still have the ND error code after you have assured you have no blockage in either of the above mentioned areas message me back for further diagnosis. Also after you clear the clogged area make sure you unplug the unit for 7-10 minutes this causes the control to reset which is easier then you haveing to go into diagnositic and clear the error code. I await your reply Thanks Rick
Aug 27, 2011 | Maytag MAH8700A Front Load Washer
Won't drain completely
Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe and that the pump is actually operating. Check the filter to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jul 09, 2011 | Kenmore Dishwashers
Nd code how do I fix
"nd" code indicates that your washing machine is not draining as it should.
To solve it, check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
Hope this helps.
Jun 07, 2011 | Amana Washing Machines
Duing the wash cyce it stopped and the code ND is showing
ND = No Drain Error
You will need to check the filter on the machine for blockage.
Jan 23, 2011 | Samsung WF328AAW Front Load Washer
Samsung WF203ANW Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
