Question about Bose Cinemate Digital Home Theater System Speaker
Bose cinemate will not power on. light stays red?
  • 2 more comments
  • Anonymous Jan 28, 2009
    I have the same issue... the unit won't power, green light doesn't come on at all. Anyone...anyone??
  • jse1170 Feb 02, 2009
    I cannot get my cinamate LED light to turn green?
    Help I have the same problem.
  • Cole Moren
    Cole Moren Aug 12, 2017
    there is not light on mine
Make sure your system is not plugged into a surge protector. Sometimes a surge protector will foul the system up, don't know why. lol. I fought with my system for 3 hours trying to get it to work, then moved it from my surge protector to the wall and it came on. If that doesn't work, try disconnecting the receiver module itself, wait 60 sec, then plug it back in. If that still does not solve the problem, I would suggest calling Bose Customer Service..
Posted on Jan 29, 2009
Thanks rbolan82! I was having the same problem and your response DID THE TRICK!
Posted on Jan 03, 2010
  • Angus
    Angus Dec 08, 2013
    This is weird. I unplugged from the surge suppressor at it worked first time, My unit was down for months i tried everything even thought of changing the optical receiver. Thanks much
    New Friend:
Same exact problem!!! My Bose Cinemate will not power on at all!!! Tried surge protector, no good, tried plugging into wall outlet, still no good. Tried replacing battery in the remote, still no good. Called customer service, did everything they said, still no good!
Returing the Bose Cinemate II tomorrow and going to get a new one to see if I simply got a lemon.
To test that your remote is in fact working use a smartphone camera and point the remote towards the phone when it's in camera mode. Press any button on the remote and the camera will actually show the IR pulse (or not if the remote is broken)... Cool way to check it!
My remote works so that only means that my Bose Cinemate II is a dud.
MAJOR DRAG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! bose cinemate will not power - 741a77f0-a1aa-412d-89af-1918b830f84d.jpg
Posted on Feb 21, 2014
2 Suggested Answers
cjackHD
  • 71 Answers
SOURCE: same problem. Bose CineMate light went red and
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Posted on Jun 22, 2009
My bose cinemate wont turn on
It is most likely a problem with the acousticmass. There has been a lot of issues with the Bose cinemate. Most of these issues require you to contact Bose. Make sure you have proof of purchase. They will charge a flat fee to fix it or if they can't they will offer you a discounted one as long as it's covered under warranty. 10_21_2013_5_59_43_am.png
Oct 05, 2013 | Furniture
Bose cinemate troubleshooting
If the light on your control console just stays red and never changes, then the control module is probably bad. It's pretty common on the cinemate models.
Jun 06, 2013 | Audio Players & Recorders
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
When I plug in my cinemate system the green light on the interface module won't turn on and power up. It only stays red and doesn't respond to the remote. I have unplugged and reset the system and check...
probablemente no este ccodificado el control remoto asegurate de poner pilas nuevas y trata otra vez checa los cables que van al modulo interfaz ya que pueden estar quebrados o sustituyelos o bien el sistema de interfaz no funciona o llevalo al centro de reparacion bose
Apr 21, 2010 | Bose Cinemate Digital Home Theater System...
Bose Home Theater system won't turn on
is the red light on?if it is just unplug power until the red light fades then pug back in then turn unit on
Aug 08, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
No green led light on bose cinemate system
I had the problem, after a lightning surge through our house, that destroyed item connected to the telephone lines. The Cinemate interface unit stayed red (powered), but could not get green light to come on, and obviously no audio. Found through Bose tech support that the the units are failing from surges "too often". They are trying to find out why and fix the longterm problem. Tell them you had a power surge (which you likely did), the green light won't come on, but the remote works with TV, etc. They will send a UPS Return Tag for you to send back the small interface unit (only). Upon receipt, they will 2-day air you a new one. It solved the problem.
Jul 13, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Jan 09, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
2,746 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
