Question about Durabrand DVD-1002 DVD Player
Keeping the DVD player going
When I put in my DVD and close the lid I can't keep it going. It will go for a little bit then it will stop and tell me "No Disc". What can I do to fix this.
  • 9 more comments
  • Drygngrl Nov 08, 2007
    I also get no disc but when trying to use a disc cleaner is doesn't read that at all.
  • Mudmaker Nov 12, 2007
    Yep BOTH of mine have done that....its start out just now and then...then doesn't matter what you do it will say NO DISC....won't buy another one of these players.
  • sweets83 Nov 30, 2007
    keeps on saying no disc
  • Anonymous Dec 04, 2007
    I have the same problem. When i put a DVD in it will NOT playing it just keeps saying No Disc. I have not even had the dvd player for more than 5 months!
  • Anonymous Dec 07, 2007
    Player won't load DVD. Reads no disc
  • Anonymous Dec 25, 2007
    tried to play multiple dvd's with the same result "NO DISC"
  • Tia1 Dec 27, 2007
    I have a portable DVD 7" screen DVD and a DVD-1002. I have had them both a year this pass Christmas. After 6 months of purchase both products are not working. They will not read disc at all. I didnt use them much at all because one was for travel and one for my personal use. I am very dissatisfied with this brand. I need help in getting my monies worth out of these products or replacement.
  • kjacquemart Dec 30, 2007
    We have the same problem - you'd think we would have learned after the first two DVD players stopped working for unknown reasons. Our less than 6 month old player - keeps telling us no disc - but reads the lens cleaner just fine - multiple tries with different dvds same result - no disc. This will be the last of this model we buy. Cheap is as Cheap does... which is not much. Lens Cleaner didn't work at least not for us.
  • zoom8754 May 27, 2008
    same problem...it says NO DISC wenever i try to play a DVD..but VCD and MP3 discs are playing fine.
  • madaket Jun 11, 2008
    I insert a disc, close the lid, it says "loading" then says "no disc".
    What to do?
  • lighthouseof Nov 06, 2008
    Man, same story less then a year old and rarley used. I have literally watched a dozen DVD's on this and its reading No Disc. Such a convenient easy to use little package too, has anyone contacted their customer support or tried for a refund? Tony [email protected]
My problem is dvd 1002 say no disc
Posted on May 16, 2008
    Problem Solver:
  • 6 Answers
If you can get lens cd cleaner try to run it for some time then play your dvd cd to conffirm
Posted on Jul 14, 2007
    Genius:
  • 1,036 Answers
The problems with dvd & cd players, are located in two areas - both mechanical.
#1 On the laser cartridge, there are minute springs that hold the lens while a coil and magnet arrangement moves the lens (similar to a speaker cone) to focus on the disc. These springs become weak and break on the cheaper models - Therefore it can't see the disc information clearly - and the output is not digital - it says no disc.
#2. The main bearing at the centre of these drives can run dry and start to become rough. This may cause the disc to wobble enough to start to vibrate. This failure is characterised by a noisy drive just before giving up.
So use a product that sources a quality optics package, and a decent framework.
It's amazing that the electronics can compensate for cheap build quality - but they do! - a bit like good suspension compensates for bad road quality.
Posted on Jun 11, 2008
SOURCE:
Door keeps opening on our Go video dvd player. we put the dvd in hit close it cloes says loading then opens
try to pull the dvd tray little bit before you close it. Hope this info resolve your Go-Video problem.
Mar 13, 2011 | GoVideo DV2150 DVD VCR
Matsui PL700 lid won't close properly
no need to tighten the cap or whatever, that's the problem there is with the switch control, which must be touched when the lid closed. you just need to open the DVD case cover, then locate these switches, make sure the switch is still normal or not, if it is normal that you only need to give a little pad on the suppressor to the switch. suppressor usually exists on the DVD casing.
Jul 26, 2010 | Televison & Video
I put a dvd in my portable dvd player and close the lid on the dvd player but it keeps sayin its open when its shut!! therefor it wont play any dvds!
LID SWITCH IS BROKEN, CHANGE IT OR THE COVERLID WHICH HAS A SMALL 3MM SIZE OF PLASTIC MATERIAL WHICH PRESS THE SWITCH WHILE CLOSING IS BROKEN TRY TO MODIFY IT...
Oct 13, 2009 | Goodmans GCE5000 Portable DVD Player with...
I put an HD-DVD in my player but it keeps coming back out.
Temporarily you can hold the lid closed with your hand and press play and leave the lid after it loads the disc. But for permanent solutuion you will require to repair its lid switches,
Aug 22, 2009 | Toshiba HD-A30 HD-DVD Player
Denon 9000 skips after an hour of use
it sounds like you have a heat problem,try to put your player somewhere that it has alot of room to keep cool,i've noticed some people put there players on top of the t.v. or close to other electronics,the whole key is keeping things cool,let me know if this helps because you have a very good player.
Dec 06, 2008 | Denon DVD-9000 DVD Player
Lid Closure
OK - There is nothing that drives the door to close and stay closed. There is a little plastic gismo the locks onto a little protruding tongue in the lid keeping it closed. To release the lid, you must press the lid foreward so that it releases the lock in the little plastic gismo. I found this out only after removing the board above the main deck of the player and which, fumble-fingers me, I managed to damage the board and will have to replace it along with the little plastic gismo that holds the door closed. I am not sure if either of these parts are available as I have had the unit for quite a while. This leaves me in a quandry as I really did like the little player. It was a dandy. So, if you ever get an inquiry on how to keep the lid closed on a JMC_800, tell them to replace the little plastic gismo and that will do it.
Aug 29, 2008 | Jensen JMC-800 CD Shelf System
Lense not reading properly
Check to see if it is not the lens, but rather the fact that the little tab on the lid that closes the disc compartment is not making firm contact with the mechanism that tells the disc to play. I had the same problem (player would play for a couple of minutes, then it's stop and I'd get an "Open" message. I called Mustek and they unhelpfully suggested various tricks to do with the lens carriage, none of which worked. On my own a carved a matchstick to the shape of the tab on the lid, and stuck it in there. That worked! Eventually (since you can't watch it with the lid up), I just put some duct tape (a little pice) around the tab, and that has worked like a charm. Makes it hard to open the lid again (I use a knife to pry it up), but hey--the player works now!
Jul 09, 2008 | Mustek MP72 Portable DVD Player
PinkDVD Portable PDL805
sounds like the switch to tell the unit that the door is closed is either loose installed at factory incorrect. or your grandchild has closed the top a bit vigorously and snapped a bit off it. open the lid and there will be like a plastic pin coming from the lid,check to see if it is broke. if not take it back to shop as its a manufacturing fault
Jul 01, 2008 | GPX MW3837 MP3 Player
Portable dvd player Film's stop and go back to loading screen
Not sure it's a solution, per se, but I discovered that my Matsui was acting as if I was opening and closing it, so I guessed that it was the lid. Once I put a paperweight on the "Press to Open" part of the lid, the DVD played through. I'm looking how to fix the lid but that's a workaround for now. Best of Luck - M
Jan 26, 2008 | Televison & Video
Open message when closed/disc wont spin
I figured it out, it was the little plastic sensor stick that tells the unit that the lid is closed therefore reading the disc. cheap piece of plastic that has surely snapped on many a unit. good luck replacing it. i rigged it though problem solved
Sep 16, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Durabrand DVD-1002 DVD Player Logo
96 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
