Question about Dell 3110cn 3115cn and 5110cn Color
005-301 error adf error - Dell 3110cn 3115cn and 5110cn Color
ADF cover is open
Sounds like a sensor is broken. Whatever caused the initial errors was not fixed and continued use has permanently broken the product.
Mar 16, 2015 | Brother International Inkjet Multifunction...
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
How do you fix error code c55
Here are the steps they recommend in the users manual for a c55 error.
5.1.11 Optional communication related service call
[C55] ADF I/F error
[F11] ADF I/F error
(1) Check if the connector CN71 on the ADF/RADF board is disconnected.
(2) Check if the relay connector between the ADF/RADF board and the PFC board is disconnected.
(3) Check if the connector CN246 on the PFC board is disconnected.
(4) Check if the connector pins are disconnected and the harnesses are open circuited.
(5) Check if the conductor patterns on the ADF/RADF board and the MAIN board are short circuited
or open circuited.
(6) Replace the ADF/RADF board.
(7) Replace the MAIN board
Jan 05, 2013 | Toshiba e-STUDIO166 Printer
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
Error c620
SC620 B Communication error between BICU and ADF The BICU does not receive a response from the ADF main board for 4 seconds or more. The BICU receives a break signal from the ADF main board. • Poor connection between the BICU and ADF main board (DF connector) • ADF main board defective • BICU defective
Apr 07, 2010 | Ricoh Aficio 2020D Copier
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Lexmark x632 scanner error(046005 adf lamp failure)
There can be a few causes of this error:
1) Firmware Revision is not latest and lamp warm-up time is too short - update firmware first:
http://support.lexmark.com//printerfirmware/
Type in: b103scan
2) Flatbed Lamp has failed and needs replacing.
3) ADF Optical Assembly has failed and needs replacing.
4) Most Common Cause:
ADF Optical Assembly Mirrors are dirty and need to be cleaned - Remove plastic cover from ADF and then remove ADF Optical Assembly. Remove the screw from one end and slide out the two mirrors - clean these and the mirror which is fixed.
Cheers Ross.
http://www.reboot.com.au
Jan 27, 2009 | Lexmark X632 All-In-One Laser Printer
ADF Document Jammed
Have you tried manually rotating the ADF wheel back and forth, sometimes the sensors are OK but the rotators lose grip.
Oct 23, 2007 | Brother MFC-8440 All-In-One Laser Printer
Open Questions:
Dell 3110cn 3115cn and 5110cn Color Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
