Question about JBL On Beat Rize iPad iPhone Alarm Clock and Docking Station - Black
Jbl onbeat rize did not alarm - JBL On Beat Rize iPad iPhone Alarm Clock and Docking Station - Black
  • kriengsak
    kriengsak Jan 19, 2013
    While using AmpUp JBL app.
I would like a full manual for the JBL xtreme speaker?
JBL Xtreme ' Splashproof Bluetooth Speaker with ... - JBL.com
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.7 - ‎35 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours playtime, dual USB port can link multiple speakers and ... Product Specs & Manuals.
JBL Xtreme ' Splashproof Bluetooth Speaker with Powerful ...
uk.jbl.com > Wireless > Portables
JBL
Rating: 4.8 - ‎36 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours ... http://uk.jbl.com/bluetooth-portables/XTREME.html? ... Product Specs & Manuals.
Jan 05, 2016 | JBL Audio Players & Recorders
How to open up the JBL onbeat rumble?
The power connection on my JBL Onbeat Rumble stopped working also. I could usually jiggle it to get it going but this wasn't a reliable solution. I note there were a few people online that have complained about this but no solutions or disassembly guides. With nothing to lose I set about pulling the unit apart to fix it... here's hoping it will help others:
1. Under the orange base rubber there are five screws. You need to carefully peel off the rubber to get to the screws. Also under the sticker on the input/output section there are two screws to undo.
2. See photo for positioning of rear clips. You might be able to use an appropriate tool to undo them. I used brute force to open the case and the rear clips didn't break.
3. There are two more clips and two screws at the front of the unit.
I don't know how to get to the screws - possibly you need to unclip the front of the unit and grille. I just used additional brute force which undid the clips and snapped the screw mounts. The unit was then completely opened up into two halves.
4. You can now get to the input/output section. There are four screws to undo before you can lift it out. In my case I could see a cracked solder joint on the power input so I re-soldered it as best I could and confirmed the unit was now being powered up reliably.
5. To reassemble, reseat the input/output board, clip the unit back together, re-insert the 5 base screws + 2 input/output screws, then glue the rubber back on (it might be sticky enough not to need additional glue). The snapped screw mounts don't seem to matter as the remaining clips are strong. Just shake out any plastic pieces to avoid rattles.
Jun 13, 2015 | JBL OnBeat Rumble Wireless Speaker Dock...
My JBL Onbeat Extreme has blown a speaker - I want to repair it but cant work out how to open it... there must be clips or screws somewhere
First you have to remove all of the bottom rubber feet, don't worry they are glued to the bottom, then with a sharp knife, remove the plasticdecal where the USB, AC and video plugs are. Pry it off from one corner then work your way all around, there you will find three more screws that will release the board. Good Luck!!!
Dec 20, 2014 | JBL OnBeat Xtreme Speaker
Jbl instructions
Took about 3 seconds on Google, including typing in the product name. These things are not difficult. You should try it. JBL OnBeat MINI Black JBL
Aug 15, 2014 | Harman JBL OnBeat Mini
My new JBL onbeat xTreme when connected to my MacBook by Bluetooth and playing streaming from Spotify, keeps goimg into stand-by every ten minutes. It seems that it doesn't recognise that it is c
Same here. Streaming from Spotify from iPhone5..... every 10 minutes enters sleep mode. WTF? No idea how to get around it. Only FW upgrade I guess, if there any...
Dec 06, 2012 | JBL OnBeat Xtreme Speaker
I have the Jensen 1020. How do I set the alarm... it didnt come with manual?
Here is the manual I hope this helps. Just follow the link to download it for free.
http://www.retrevo.com/support/JBL-P1020-manual/id/596bh930/t/2/
Oct 12, 2010 | Car Audio & Video
Voyager transmission problem
Sounds like you need a solenoid pack to start, and possibly a service. If the tranny is not slipping, the solenoid pack is stuck and not tell it to shift up. Could possibly be a TCM, but not as likely.
May 30, 2009 | 1999 Plymouth Grand Voyager
Rize z3
go to main menu
then settings
then home screen
and click on clock
and it should be checked as digital
if its not then select it
and if that doesnt work
then i have no idea
Dec 12, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
JBL On Beat Rize iPad iPhone Alarm Clock and Docking Station - Black Logo
54 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
