Question about KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator
Falling water hits something hot in freezer and causes sizzle sound
I notice a sizzle sound in my side-by-side (freezer part) tonight. I removed the bottom drawer and heard the sound coming from behind the louvers in the back. Saw slow drip of water sometimes hitting something hot and heard the sizzle sound. Haven't had any problems before - no icing up. Did notice tonight that there was a slight amount of water (less than 1 oz) on the floor on the freezer side. Any ideas as to cause and recommendations on how to fix? Thanks, bob
  • Anonymous Mar 31, 2009
    exact same problem.  please confirm my fridge/freezer is not going to catch on fire and all is well.
  • Anonymous Mar 16, 2014
    water on the floor on freezer side, need to look behind grill...does the grill snap off, i dont see any screws....what is causing the water
    President:
  • 1,462 Answers
The sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Posted on Jul 13, 2007
SOURCE:
Freezer leaks water out the bottom
sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Mar 22, 2014 | GE Refrigerators
I have a ge side by side refrigerator/freezer and i'm hearing a sizzling sound from the freezer side. Sounds like water is hitting the heating element causing a sizzling noise. Should I empty th
If you are sure the sound is coming from the freezer side, then yes you should empty the frrezer and take off the rear shield. While the heating element is normally encased in glass or plastic. Water droplets hitting an electrical connection could also cause a sizzling sound.
Feb 03, 2012 | GE Refrigerators
I've never noticed this before today and I'm not sure if it's normal or not but there is water dripping onto something on the freezer side. It makes a sizzling sound when it hits it. I...
when in defrost there's a heater under the evap coil in the freezer,all you're hearing is the water from the frost melting off of the coil and hitting the heater,this is a normal thing so don't be worried,you might even see an orange glow in there through the holes or at the bottom of the back inside freezer panel,it's just the heater doing it's thing,then the water goes into the drain and down near the compressor where it will evaporate,
Sep 04, 2011 | Refrigerators
I have a Whirlpool ED25PWXAN0 .. it stopped cooling in the fridge and freezer, when the freezer started gettimg warm I could hear a sound coming from the bottom of the freezer, it sounded like drops of...
Look at the drawing part #6 is the defrost timer.
Directly below that is a hole about the size of a dime its an access to a part of the timer you can turn with a flat tip screwdriver. There is a small removable cover there so here is what to do.
Open the fridge door and look up at the bottom of the control panel.
Remove the cover if it is there.
Slowly turn the timer you will hear it click until your unit comes on you will be able to see which way it turns as it is designed in a manner that a flat tip will only turn it one way.
That should get it going for a bit you will need a new timer.
Thanks for asking.
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2010 | Freezers
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Water dripping in the freezer We have side by side kenmore fridge and freezer and filtered water. I just opened the freezer and heard dripping of water behind back cover. It sounded as water is hitting...
this IS normall. the freezer is just in defrost cycle. the heat elements are on and defrosting the evaporator. you are hearing the water hitting the elements and running to the drain. this is normall, does it every day, just the first time you happen to notice it. shane
Aug 25, 2009 | Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Logo
2,257 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
