Question about SanDisk Sansa m240 MP3 Player
Sansa SanDisk mp3 out of power
I connected my sansa on to Usb port of my PC.
The PC was out of work, Means power off.
I let my Sansa connected to the PC till next day, I turned my PC on whith connected Sansa mp3 player on my PC.(the player was off, then and after turning on my PC).
Now i can not swich my Sansa on ?? Nothing is working......
Have taked lookings at the hardware manager, working place ..... can not find the mp3 player. I tryed also an other usb port.
my Sansa is still out of work and i can not swich it on. connected and disconnected to my PC.
Before it was working verry well. i never forgot the player connected to the Usb port of my PC before.
Is that maybee the problem, I let it connected and the battery is going totally down? What's Happened ? What can i do now? And how can i do it?
can annyboddy help plz...
    Scholar:
  • 51 Answers
Try these:
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Posted on Jan 27, 2009
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
How do i charge my mp3 player/sandisk sansa m240
Connect the USB cable to the MP3 player then power up a computer and plug this MP3 and cable into the computer's USB port.
You can also charge it by purchasing a 5V USB power adapter and plugging the MP3 player and cable into this adapter.
Jan 04, 2010 | SanDisk Sansa m240 MP3 Player
Sandisk sansa fuze not connect to the pc
Could be a couple of things. There may be damage to the USB port on either the player or your PC. The cable may also be defective. If you are using an older PC, it may not use the right USB technology for the device. Newer devices use USB 2.0 which looks the same as the original USB technology, but is much faster.
Oct 26, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk sansa mp3 - port power limit
Try unplugging a few of your other USB devices,
Apr 21, 2009 | SanDisk Sansa Clip MP3 Player
My XP system does not recognize Sandisk Sansa e260
The XP did not recognize the device because I used a after- marked USB expander board that did not provide enough power to the device. Plugging to the Motherboard - attached USB port solved the problem.
Mar 20, 2009 | SanDisk Sansa e250 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa c240
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Connection problem
its the usb connection you probably connected to hub with bad usb port or needed update usb parameter port
Apr 11, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Frozen screen
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
