Question about Frigidaire Kitchen Ranges
Model reg433 range frigidaire
Frigidaire model reg433MD2 30" drop in range. Need replacement for clock timer.
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
Junoon007
  • 1011 Answers
SOURCE: Frigidaire Range model FEFL79DSJ has electronic clock/timer
Dear Sir/madam,
Connect an ohmmeter across the terminals and advance the timer to see if the switches
are opening and closing OK. If not or the motor doesn't run - replace the
timer. Since the burner is
inside the oven, you cannot immediately see if it has ignited. Different manufacturers have designed
different methods of keeping the
gas safety valve closed, until ignition is guaranteed. The oven
thermostat valve is set by hand to control the oven temperature. In some types of systems, the
thermostat is not a valve at all, but an
electrical switch that opens and closes by oven temperature.
The
gas safety valve prevents gas from flowing to the burner until ignition is assured. If it has an
electrical thermostat, it cycles the safety valve. On and off as long as there is ignition.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 29, 2008
  • 323 Answers
SOURCE: Need to replace drop in range
All you have to do is make sure you have the same drop in top as the hole cut for it. Measure the opening, and then measeure flange to flange on the one you have. The flange will be 1/2" or so bigger than the hole; that's what holds it in.
They are ususall 30 or 36" wide. It doesn't have to be a Kenmore, just match the color to everything else.
Need to know how to disconnect it?
Dan
Posted on May 11, 2009
  • 6 Answers
SOURCE: GE XL44 Gas Range JGBC15GER2. Can't see clock on
yes it is called a electronic oven control go to ap wagner.com and enter the model number and you can get priceing
Posted on Nov 08, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a frigidaire gas range model # fgf337ecc
This is your electronic control board that has gone out. When you order yourparts through us, we provide part removal/installation instructions for our customers.
We also ship overnight and would love to get you cooking again real soon.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number. Thanks, Ella
Posted on Nov 18, 2009
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
My stove panel went blank.
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Mar 22, 2014 | Kitchen Ranges
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2010 | Frigidaire Ovens
My stove works but my oven wont, and the light of the oven wont turn off
Without a model number, my guess would be a stuck relay in the electronic clock/timer. Replace the Electronic clock/timer.
Jan 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Replace clock on range
there is screw on back of range. remove screw and pull of back cover. that will expose clock. make sure you unplug unit first. don't forget where wires/plugs go
Jun 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need clock overlay touch pad can't find compatible part
Hi, I can get you the overlay. It is about 30.00. It is black in color.
Vic
May 20, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Is their a reset button on a frigidaire elctric range model ES300
clock, timer, temp gauges for oven shorted out, is there a reset button?
Jan 09, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
59 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
