Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
Multimaster driving shaft worn - Fein Multimaster Rs - Msxe 636 - 2 Rs
Where could i buy a new switch and capacitor for my multimaster Msxe 636 - 2thanks
A capacitor is in in practice not nessecary but sometimes its only inside for radio interference suppression. remove it the switch is if you not know it also made to disassemble because of all its a realy dirt sensitive, but rarely defect i have never replace this part in all the time this year 20 years switches of this model al very little screwdriver is neccesary open it a little not neccesary to dismount it completely and spray wd40 inside wait a moment and blow the dirt carefully out remount and control always the AC cable for shure after.
Jan 28, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Where does the long lead go on my multimaster capacitor go
Close to the bottom in the corner near the motor stator (= electric field) between the machine housing and the stator there is a narrow metal strip connection point visible which makes contact with the metal outer surface of the stator, the strip sits against the corner on the underside between the motor stator and the machine housing from the front so pushed to the back comes out so at the contact side of all sliding contacts you will see are that part, I myself always recommend letting eight jure the capacitor because it only makes sense for radio interference suppression only at work places.
Aug 22, 2012 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Multimaster stopped working
First control the brushes for the length or a spontaneous broken cable . or elecric modul has MEASURE is neccesary of the 4 electric field contacts also.
Dec 22, 2011 | Fein Multimaster Rs - Msxe 636 - 2 Rs
A friend who bought a multimaster less than a year ago has had his start a loud 'clattering', dry, noise, and the gearbox started to get hot. The output shaft now has about the same amount of slop as the...
Fein is an excellent tool and has an excellent warranty that will be void the moment you open the gearbox. I do not recommend this action. Fein is quick and responsive, especially for a less than one year issue. Farmerbear at FixYa.com
Sep 30, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
I can't keep the attachments from falling off while in use. I suspect I need new hardware, but cannot find instruction for Fein msx 636 II
Are you fully opening the lock lever when you are putting the attachments on? If you are new to the machine, you need to fully open the locking lever on top, insert the attachment and be sure it "seats" in the shaft holder and then close the locking lever and be sure it is tight.
Sep 14, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Where can I purchase a switch for the MSxe 636 II Fein Multimaster?
http://www.ereplacementparts.com is one of the online shops in you Country or a dealer for FEIN in your immediate environment.
Jul 29, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Hi. I have an older fein multimaster msxe 636 II. The blades have round bolt holes. The new models have the star type holes. Can I use the star type blades since they are more available?
With respect to the above "answer", this tool has NO locking lever! It uses only a set screw to hold blades in place. It so happens that newer "star" mounting blades will fit into this tool easily, One must center the blade so the fingers of the star are outside of the raised circular surround of the hole. A washer (use a larger tapered one) and the set screw will then press the blade against the back surface of the bit holder. Tighten up this assembly, turn it on a cut away!
Dec 30, 2009 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Multimaster
these are pressed bearings and you have to put the head in a vice (carefully as it is cast aluminum) and use clamps to keep in in place while you hammer on the driving shaft flange (where the blades attach) it is a slow process, there is a locking spring that has to be released first. Then when the pressed bearing is loose you will still have to tap until the shaft comes out of the level (part with two prongs). afterwards you must pry out the armature carefully with a screw driver against the fan, be careful, this tool is not really meant to be worked on by us owners, obviously, and for this reason it sucks big time,
Sep 27, 2008 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Not oscillating
Hope this helps!
Inside the gearbox there is what should be a 2 pronged fork you may only be able to see 1 of these the other may be broken, the fork goes each side of the armature bearing. If the fork isnt broke it may be the armature bearing that fits inside the fork.
Hope that helps. Sean
Jul 26, 2007 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
21 people viewed this question
Top Fein Vacuums Experts
Bill Boyd
Dan Apthorp
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
