Question about Refrigerators
Norcold refrigerator door seals model N821
Need to replace door seals, Cannot find any replacements.
  • 1314 Answers
SOURCE: Fridge does not get cold enough
first the freezer does all the cooling there are air vents in top of the refrigerator that the evaporator fan draws air through then blows it down to cool the fridge in the fridge section you should see an air vent if you don't have a defrost problem then you have an air flow problem first do you hear the fan running if you see heavy frost on the back wall of the freezer wall where the fan is then you have a defrost problem and that's a different repair but if you don't then remove the four screws and pull the panel carefully as the fan is there see if there is heavy frost on the evaporator a large aluminum honey comb so much that air cannot come through it under that part will be an a tray with around hole in it make sure that's is not frozen and the drain hole is open then check that the square hole that goes down to the fridge is clear and check the two square styrofoam intake blocks are clea you an pull them out gently and see if its iced up under there after you check that reply to me on any fault
Posted on Dec 31, 2007
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
Techsim
  • 59 Answers
SOURCE: GE Profile Door Seal
There is a cam at the top of both doors the grab on to the fridge to hold the door s shut. There has been a problem with them breaking and not holding tight. Check the door and make sure the cam is gripping the cabinet correctly.
Posted on Nov 02, 2008
herodog909
  • 98 Answers
SOURCE: Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
Posted on Jun 18, 2009
  • 35 Answers
SOURCE: Frig does not go below 52 degrees.. Freezer OK
MAY HAVE PUNCHED HOLE IN EVAPORATOR AND GAS LOW????
Thetford gas igniter burns but ignition is not seen by control unit
Without the make & model...
the only answer possible is a "TYPICAL" SWAG: Looks like NORCOLD is most likely your manufacturer (although I've also seen U-Line).
SPARES are good to have... (now you understand).
On-Line parts abound everywhere... It is likely an "electric"
(because of your control board statement).
I'll put up sample Pix from Amazon & eBay.
http://www.ebay.com/sch/i.html?_nkw=Norcold+Refrigerator+Thermocouple
Your THERMO-COUPLE (flame monitor)... same (type) thing that always fails on our water heaters... typically costs $6 if you are buying one in advance... up to $24 (twice that for the "Refrigerator versions" $12 to $48) in you hour of need... Unless you call a "service" (plumber) person... Then just start adding on those ZEROs.
These also can use an INTERRUPTER (same price range)...
Buy them both... As you can tell... they are good spares to keep around (I always buy a NEW thermo-couple & put it on a nail
with a "NEW water heater installation (keeps evil spirits away).
I'd recommend you post the complete make, model & year...
Defective GAS appliances can be quite deadly... even if the work is done properly... improperly the sky (is quite literally) the limit...!!
Could NOT more strongly URGE... Buy and USE a good carbon-monoxide monitor/alarm.
Truly a LIFE-SAVER.
All gas utility companies will (or used) to QUICKLY send out their representatives to inspect/light gas appliances..
Historically this was always a FREE SERVICE...
(but sadly that the extent of my knowledge... HISTORIC).
Be safe... Comment me back if you need:
(never test for leaks with a match... My grand-daddy taught me that (course hair & eyebrows grow back... MOST of the time).
Norcold Refrigerator Thermocouple
Apr 11, 2016 | Refrigerators
Norcold DE 828 on my boat. Haven't been able to replace door seals as no one makes them anymore. Compressor was always loud and always coming on. Recently, no compressor noise only a buzzing or...
Hi Macias
Norcold still should have door seal parts available for this, the parts manual available at this link
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/DE828EV828Series/tabid/499/Default.aspx
If the compressor is working then the condenser at the back should feel warm while the compressor is running, some of these have a single compressor and some two compressors, the units are fitted with independant power supplies so I would check these first. If you need any further info please come back to me
Regards
Gordon
May 05, 2011 | Refrigerators
Light in refrigerator does not go out when door is closed. We replaced the switch but the light still stays on when door is closed. Can you tell me what the problem is?
To make your search simpler and understand the way to search Norcold Manuals is to always remember Norcold and Dometic models will always come up with different search names. Confused? Click here to bigin your search=> Norcold If you are unable to get results then click=> HERE Once and at top and bottom of page=> Here you may contact me for more answers to your questions regarding your NDR1292, Thanks, Sea Breeze
Mar 20, 2011 | Dometic NDR 1292 Refrigerator
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
Frig will not cool
Jun 18, 2009 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
