Question about Electrolux E23CS75DSS Stainless Steel
Electrolux Icon Freezing up and no longer cooling
Hi, I purchased the above fridge brand new and about 3 months into owning it, it started to freeze up and not defrost itself. I then have to manually defrost, then plug it back up. I had a repair guy come put a new board in it, and that didnt fix the problem. He then took it out, my electronic guages no longer work.... That fixed the problem for 2 weeks, then it froze up again. Any thoughts?
  • justin harrison Jul 14, 2007
    Hi, Actually the repair man was sent out by the manufacturer. Any idea who else I can call>?
  • Anonymous Jun 24, 2008
    I have same problem , what was the solution . Please help
    Novelist:
  • 159 Answers
You have a definate defrost problem if the evaporator keeps freezing up. Since your refrigerator is under the manufacturs warrenty you need to make it there problem and get them to send someone that knows what there doing to resolve your problem. there is a timer a terminator and a heater he would need to check out. Good Luck
Posted on Jul 13, 2007
Hi, I have a Zanussi ZBB28440SA integrated fridge freezer, the fridge section is no longer cooling yet the freezer seems fine? Any help would be great!
unsure as to what problem might be , but refrigerators at 16 degrees would be freezing things solid here in the US if you are suggesting the temp is in centigrade them perhaps the damper motor controller has failed on it and you need to seek professional help to replace it
Dec 31, 2017 | Zanussi Refrigerators
Electrolux fridge freezer not cooling or freezing
If the compressor is not coming on then first check the start capacitor and if this is good then check that the contactor or relay is working properly Hopefully its one of these if not it may be the thermistat but probably the compressor has siezed.. I know this sounds wierd but if u can gain acces to it tap it with hammer this will some times unsieze them
Jul 24, 2012 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
I'm having trouble with Maytag model MF12067AEB refrigerator that started about 6 months ago. The vegetables/fruits are freezing in the bins....the repairman has been to my house 3 times....replacing the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Maytag Refrigerators
Not defrosting. I replaced the defroster timer circuitry and heater element last April. It worked for 3 months or so and started freezing again.
heatman101
Aug 29, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a problem with my refrigerator not cooling consistently. It seems like at least once a day it will start warming up but the compressor doesn't come on. When I turn the temp up control nothing...
I believe this is normal behaviour in all auto defrost (which means virtually all modern) fridges. In fact, this short heating period is usually programmed to happen 2 to 3 times a day. You might rightly ask why the refrigerator compartment needs to undergo "defrost" cycles when the compartment is, if the refrigerator is operating correctly, above freezing? The reason is although the compartment is above freezing, its cooling coils are well below freezing temperature, and it's these coils that need the frequent defrosting, before they build up so much frost on them that they "ice up" and no longer allow the fan blown air that cools the refrigerator compartment to pass through them.
Nov 12, 2017 | Kenmore Refrigerators
GE PFS22MISBWW is a piece of junk
One doesnt like to hear it but possibly cut your losses and look for a less complicated fridge with minimum electronics.
Jul 21, 2009 | GE PDS22LBN Bottom Freezer French Door...
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Jun 22, 2009 | LG Refrigerators
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
Electrolux E23CS75DSS Stainless Steel Logo
209 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
