Question about Carrier Heating & Cooling
My outdoor heat will not operate. It is a Carrier 38YRA042330, with a Carrier Thermidistat thermostat and a Carrier Air Handler 40FFKB005300. I have an H5 error code on the thermostat will I put it in Heat mode and raise the setting to call for heating. I changed the air filter on the air handler when I realized the heat pump was not operating. The air filter was pretty dirty. The system will operate in aux/emerg heat mode, with the fan in Auto or On mode, and will maintain the thermostat temp setting. Thanks for your help. James Bowles Newport News, VA
  • jrbowles1 Jan 25, 2009
    There is no red reset button on this Carrier unit. I used to have a Rudd and it had a reset button and I used it, but this Carrier doesn't have one unless it is really hidden. I also took off the panels and it looked at the power/control panel, but no button in there. Thanks for the help. If you know anyone who knows how to reset a Carrier Heat Pump 38YRA042330.
  • 700 Answers
You need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Posted on Jan 25, 2009
Howto hook up th8320R1003 to heat pump
Byron, unless you have thoroughly familiarized yourself with the terminal designations on all three components, t-stat, air handler and heat pump you shouldn't attempt connection of the control. There are many variations of what will work and many more variations of what will NOT work.
No mention of outdoor sensors, so fine tuning of the electric heating stages to match the heat loss of your house (for most efficient operation) doesn't sound possible.
I know, this answer didn't help but there is no simple answer without having all the components in hand.
Mar 05, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
I have a Lennox A/C and air handler with a honeywell thermostat and the purge light is blinking. What can I do? I am not getting cold air.
check with thermostat commands from indoor to outdoor.May be your outdoor unit doesn't have command to operate.
Jul 24, 2010 | Amana PTH123B35AE Air Conditioner
Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
No heat when outside temp low When outside temp is 38 or above get heat. Is there a heater in the compressor that can fail?
I would start with your outdoor thermostat located in
the unit outside. I`m assuming this is a heat pump.
When the outdoor temthermostat is set to say 40F
anything lower than that and you are not using the
compressor, you are using electric heat thats located
in the air handler unit in the house.
I`m also assuming this is a split system and not a
packaged unit. If you are mechanically inclined and
you can locate the outdoor thermostat lower it below
the outdoor air temp and see if the unit comes on.
Sounds like you might have a problem with your electric heat or emergency heat
Jan 12, 2010 | Carrier XQB101D Air Conditioner
Carrier thermidistat screen went blank
Check the battery in the thermostat it is dead!! Should be 2 AA batterys!
Sep 11, 2009 | Carrier Heating & Cooling
York Heat Pump outdoor cutoff thermostat wiring.
You should call a professional in on this one you can damage alot of expensive parts trying to do this on your own without the proper tools and knowledge of the control logic
Sep 05, 2009 | York Yankees Bedding MLB Comforter
Carrier Programmable Thermostat - E5 Code
Ok what you need to do is call your local service company and have a technician come out and check your Thermostat, its currently not able to read humidity probably due to a power surge
Apr 28, 2009 | Carrier Heating & Cooling
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Mar 28, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
741 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
