Question about Microwave Ovens
We need to replace NN-T991SF (broken). We have a trim package and want to purchase a new microwave that will still fit with our current stainless trim
What is the new model we can use to replace the microwave with trim package we have now
MicrowaveSvc
  • 9098 Answers
SOURCE: Another Microwave that shuts down after 3 seconds of microwave operation
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. And of course at less than 1 year, this would still be under warranty if you have your sales receipt. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Good luck!
Posted on Jan 25, 2007
  • 833 Answers
SOURCE: panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Posted on Dec 17, 2007
SOURCE: looking for a G.E. microwave trim kit
I ordered a trim kit from a on-line group who will make it to fit your needs. I can't think of their name but you can find them by doing a search. I ordered the black to go with my SS mic/conv oven and it looks great. Was not difficult to install.
Posted on Jul 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
Where is the light bulb in my nn-t995sf microwave?
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 27, 2011 | Panasonic NNT995SF Stainless steel 1250...
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Need replacement microwave for 6 yr. old Thermador MBBS microwave
I have the Thermador MBBS/01 in a Theramdor oven/warming drawer/microwave unit. When I was told it would be $600 to repair it, I called thermador & they don't make a replacement. Thermador CS was even rude about it. I searched & searched for a microwave that would fit & found a GE model JEB1860M1SS at Home Depot for $259.00. My husband & I just installed it & the frame kit inside, on the old Thermador micorwave fit PERFECT! I could not believe it. I thought we would either have to settle for something looking tacky in the hole or buy a whole new unit. Looks like it came in that unit.
Sep 16, 2009 | Thermador MBBS Microwave Oven
My Panasonic nn-s262 fan and light not working. All other functions are operational. Is there a fuse in the microwave that needs replacement?
Hello, you will need to take the cover off the microwave and look for a fuse internally which should be mounted onto a pcb or electronic board.
NOTE: Be very careful if the microwave is stainless steel as they are very sharp.
Jun 18, 2009 | Panasonic NN-S262SF Microwave Oven
I need to buy a new MBBS Thermador Microwave
I spent the better part of three days trying to find a microwave that will fit and it's hard because so many are on line only. Last night I successfully installed the 2.2 cu. ft. GE profile counter top unit with inverter technology. The unit is an exact match, the Thermador even fits in the GE box with the styrofoam! I installed the venting materials for the side and rear vents and the platform at the bottom. I put the clips and decorative molding on and it's perfect! I found it in stock at Lowe's for $198. I took me about 45 minutes total to install. If I can do it, anyone can - 48 year old mom with 5 kids!
Nov 27, 2008 | Thermador MBBS Microwave Oven
Installation instructions of microwave trim
I would contact the dealer or store you purchased it form or visit Neff online at http://www.neff.co.uk
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 20, 2008 | Microwave Ovens
Panasonic bulb nn a753
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Jan 24, 2007 | Panasonic NN-P294SF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
