Question about Hankscraft Humidifiers
Need a new motor for a Hankscraft humidifier 240
Need online instruction manual for hankscraft humidifier model 240
I found this. There are no manuals available on line.
Here we have a used working HANKSCRAFT / GERBER COOL VAPOR HUMIDIFIER Model 240 WITH INSTRUCTION MANUAL and STEAMED CLEANED. This humidifier, by Gerber, has a 1 3/5 Gallon Capacity, and produces cool vapor for up to 18 - 20 hours in low, medium or high settings. The humidifier works great , does not have the directional nozzle included but does come with a copy of the instructions.
http://www.ebay.ca/itm/331790662762
Dec 03, 2016 | Humidifiers
A white dust is comming from my cool mist humidifier, is is dangerous to breathe?
Its probably just from the minerals in your water. If so you should be fine although it does make a bit of a mess around the house. If the white dust bothers you, fill your Hankscraft 240 with distillers water rather than tap water and the problem will go away.
Mar 07, 2015 | Hankscraft Gerber Model 240 Cool Mist...
How many amps does the sunbeam health at home humidifier use?
Multiply the amps time the volts = watts. .49 x 220 = 107 watts.
Jan 08, 2015 | Sunbeam Humidifiers
What is proper procedure for running vinegar through my Hankscraft cool mist humidified?
Not sure why you would want to. Vinegar is typically used to remove calcium scale that remains after a heating element or electrodes boil off water. The Hankscraft 240 doesn't boil the water off. All the minerals in the water go out the spout with the mist.
Dec 12, 2014 | Hankscraft Gerber Model 240 Cool Mist...
I just bought crane drop humidifier & happy with it.. by my silly mistake, i forgot to use step-down converter due to higher voltage(240V) in my country. It appear burn smell... look like the water...
Unfortunately, plugging a 110 volt appliance into a 240 volt source fries the motor, so buying a water basin is not going to help. Even if the heater element did not break, the higher voltage would have taken out the thermostat and probably other items.
You could replace the water basin, then the thermostat, then the element, but by the time you replaced att that, it would cost you more than replacing the unit with a 220V humidifier.
I don't like to be the bearer of bad knews, but I also have to give you the best advice (at least in my opinion) that I can.
Jun 24, 2011 | Crane Adorable Humidifiers 1-Gallon...
I need a new motor for my Hunter Humidifier model 34257
I have one if you still need it been so long ago, tonrg@netzero.com and extra parts
Jan 17, 2011 | Hunter 34257 2.5 Gallon Humidifier
What is the voltage 120 of 240?
If it will plug into standard wall socket it is 110 volts. 240 volt plug is different
Jan 27, 2010 | Kaz 4100 1 Gallon Humidifier
I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Nov 18, 2009 | Honeywell HE360A1027 Whole House...
Humidifiers Logo
55 people viewed this question
Top Hankscraft Humidifiers Experts
Mack Baxter
Dennis
Are you a Hankscraft Humidifier Expert? Answer questions, earn points and help others
