Question about Sharp AR-M237 Copier
Service Code of H4-01
I have this service code - H4-01 on my Sharp AR 337. Can you tell me how to clear it?
Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
H2-01 Fusing Temp. to low
Use DIAG (SIM5-2) to checkthe heater lamp
Blinking operation.
If the heater lamp blinksnormally:
Check the thermistor and its harness.
Check thethermistor input circuit in the
control PWB.
If the heater lampdoes not light:
Check for heater lamp disconnection and
thermostatdisconnection.
Check the interlock switch.
Check the AC PWB andthe lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble.
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKINGON MACHINE***
You have to reset fuser errors with simulation 14.Push P * C * then 14 then Start (the button you use to make copies)and it should reset the code. If not then replace the fuser.
SM5-1 should turn the lamp on. If lamp blinks on and off it is thethermistor, if it does not it is the lamp, but check the contacts onthe lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defectivereplace.
Posted on Jan 28, 2009
Service code for H3-00
fuser section has overheated. clear>pause>0>pause>14>1>start button to clear it.
Apr 27, 2015 | Sharp AR-286/337/407 Developer Black...
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
Apr 06, 2014 | Sharp AR-M237 Copier
I have a sharp AR-337 copier, On the dispaly it reads: CALL FOR SERVICE. CODE:H4-00
H4 00 Heat roller abnormally low temperature
The fusing temperature does not reach 175C degrees within 30 sec of turning on the power, or the fusing temperature keeps at 140C degrees.
C/I/0/I code 14. If it doesn't reset probably a blown thermostat on those piece of **** fusers. Also have seen the lamps some, mostly thermostat. If it has many miles on it I'd just replace the fuser.
If the previous methid wont work..., Clear --> Density select --> Clear --> Density select is for service mode.
Check code 26-30 and set to 0 - CE mark support control OFF
Try surge arrest power source.
Hope helps
Apr 22, 2011 | Sharp AR-M237 Copier
Hello, I have a Sharp AR-337 and I am getting a message: "Call for service. Code: H5-01" is there anything i can do to fix this?
Hello sir; I like you check the exit senser first see does it move freely, if yes, then do a reset procedure; press "program", "interupt", "clear", "interupt" then enter 14 press start, turn power off and back on.
Jun 12, 2009 | Sharp AR-M237 Copier
Error Code F1-00: How to clear on Sharp AR-C250
go into service mode (program interrupt clear interrupt)
enter simulation 26 sub 1 (option setup)
change to no finisher
CA to exit, and you're all set
Dec 11, 2008 | Office Equipment & Supplies
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Feb 15, 2008 | Sharp AR-M237 Copier
Sharp AR-M237 Copier Logo
559 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
