Question about Lightware Projector Lamp Projector Lamp for L 1020
Lightware L-1020 lamp does not light
I have a Lightware L-1020 with very few hours on the bulb. Now the lamp does not light when I turn it on but the lamp status and lamp age lights on top of the unit indciate that the lamp is fine. Also do you know where I can download the drivers?
2 Suggested Answers
SOURCE: VP100 Projector Powers Up But Doesn't Light Up
Well, If you are pushing the power button beside the lens and the fans speed up but no light is on hte lights might of gone out as of now i have the same projector no one has a replacement bulb but if the fans just go steady and does not speed up when you power it on the there night be a problem with the button try the remote if you have it otherwise it just might be the bulb,
Hope This Helps
Posted on Feb 17, 2008
After a few minutes the projector turns off, the red light of the light bulb starts flicking
are you managing to get into the menu at all and reset filter and lamp hours?
By the way - although optoma what cheap option for our school, i now get hitachi with 3 year bulb warrenty.... mine BURNT out luckily not at weekend or school may have gone up too - expensive optoma really then if that had happened.
good luck
Jan 30, 2013 | Optoma DH1010 OEM Projector Lamp
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Hello, I am having a problem with my hd72/hd6800. My projector is on its original bulb and has about 500 hours over 5 years. Today i was able to turn it on, but the lamp wont light up. I hear the fan start...
Despite the relatively few hours on the lamp, the fact is it's over 5 years old. It is not uncommon for a lamp to age and be too weak to fire. Replace the lamp, you should be fine.
Jan 25, 2011 | Optoma HD72 Multimedia Projector
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
My Lightware VP 800 fan turns on but when I press the power on button it powers up but no light comes on. The bulb does not need to be replaces. any ideas?
Check the bulb with a multimeter or it could be the ballast .Lots of times it an easy solution like trying another ac cord that fits better or even the ac fuse.
Mar 02, 2009 | Lightware VP 800 Plus Multimedia Projector
Power problem with infocus lp70+ projector
It seems the power supply board problem. shoud be checked by the trained technician only.
Feb 03, 2009 | InFocus LP70+ Multimedia Projector
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Hope This Helps
Jan 20, 2007 | Lightware VP 100 projector lamp Projector...
100 people viewed this question
Top Lightware Office Equipment & Supplies Experts
jasbo
jasbo
Piyal Perera
Piyal Perera
Bill Boyd
Are you a Lightware Office Equipment and Supply Expert? Answer questions, earn points and help others
