Question about HP Officejet J4680 All-in-one Printer Wireless working
Hp officejet j4680 how to clean ink stains inside of printer
I keep getting an error message about cleaning ink stains. I have used the utility feature to clean print cartridges but the problem still persists.
4 Suggested Answers
  • 46 Answers
SOURCE: incompatible print cartridge tri color error
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
Posted on Mar 26, 2010
  • 45 Answers
SOURCE: When I try to print
Clean the cartriage terminal with cloth the problem is cartriage can't communicte with printer properly
Posted on Jan 01, 2011
  • 83 Answers
SOURCE: I have an HP scanner/printer,
Its does dry out ,Try some few drops of liquid H2O and put it back but this only to bypass an error. do not try to print.Thank you.
Posted on Sep 12, 2011
It's hard to believe this story is true, but I assure you it is all true. 1- In October 2009 we purchased an HP Officejet Pro 8500. Not long after installing it we got constant messages "Printer is...
1 you said the cartridge is low.
it happens because the ink cartridge must have been used for initializing the printer which does take a lot of ink. please purchase a new cartridge and the issue will be resolved.
2 Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.
NOTE: If error messages also display on the computer, clear the error messages after each of the following steps. You might have to delete pending print jobs from the print queue on the computer to clear the error messages. Solution : Clean the electrical contacts Follow these steps to clean the electrical contacts on the printhead and inside the product. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components. Step one: Clean the contacts on the printhead Follow these steps to clean the contacts on the printhead. NOTE: The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button. CAUTION: Proceed only if the carriage is on the left side of the product. If it is not, the printheads will be damaged when you install them. If the carriage does not move over, try turning the product off and on again
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet. NOTE: Do not turn the product off by pressing the Power button (c01602202.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01817489.jpg
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle to remove the printheadc02548320.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead. CAUTION: Wipe only the electrical contacts. Wiping the ink nozzles, located on the underside of the printhead, can damage the printhead. Do not touch the nozzles. Doing so permanently damages the ink nozzles, and the ink stains clothing. Figure 3: Electrical contacts and ink nozzles c01817491.jpg 1 - Electrical contacts 2 - Ink nozzles
  9. Wipe the electrical contacts with the swab until no ink residue remains.
  10. Wipe the electrical contacts with a fresh cloth to dry them and remove lint.
  11. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
Step two: Clean the contacts inside the product Follow these steps to clean the contacts inside the product.
  1. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01817492.jpg
  2. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
Dec 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I get my ink put in by Costco. I am getting an error message saying that the black ink cartridge is incompatible. But I have used this black printer cartridge before. I do not have the money to buy a new...
Are the cartridges used, genuine HP cartridges? I know that on HP and Canon printers that the brand name cartridges seem to work better than the aftermarket ones.
Dec 08, 2010 | HP Officejet J4680 InkJet Printer
New black cartridge wont print
Hi
check expire date on cartridge
perhaps you need to replace it
or clean it from maintenence menu
of your printer
In case I had help you pls vote me
Nov 06, 2010 | HP J4680 Office Jet All-In-One Printer
Printer says-
Remove the Cartridge.
Clean the Electrical ( golden ) contacts using lint free cloth.
Clean the Contacts inside the Cartridge slot.
Put then back in the Printer and follow the instructions on the Printer Screen.
If this does not resolve.. Contact HP Support if you are using Genuine HP Cartridge for more Help.
Jun 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi, i have a HP officejet J4680 all-in-one. The
Clean every moving part with suitable substance. It will be better that you get a support.
Aug 12, 2009 | HP J4680 Office Jet All-In-One Printer
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
HP Officejet J4680 All-in-one Printer Wireless working Logo
171 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
