Question about Nokia Lumia 920
Whats does a bolt and a gear on the screen mean?
How to fit timing belt for ford fiesta 1.4 ?
1.4 petrol ,now be carefull here as if you try to undo the front pulley then bang goes ther engine ,its on a taper with no keyway .What you need is a special tool that locks the flywheel by means of teeth that go in where the startermotor is .Now what i do as iam not buying tools for every make and model of vehicle i work on is to drill a 8.5 mm hole in line with the ring gear ,then tap this to 10mm ,then screw a bolt with a nut on the bolt into this hole ,the bolt has a point ground onto the end ,then when this engages the flywheel ringear i screw the nut up to touch the bell housing and just pinch it .then and only then can you undo the front pulley bolt .Look in a haynes manual for the timing marks and then align them up and then screw the bolt in to lock the crank as described or some white paint on the cam gear to mark it in situ because as the cranks locked up it cannot move so the only gear that needs timing is the cam ,spot of white paint on gear and housing facing is goiod enough .
Aug 01, 2015 | Ford Cars & Trucks
How to service gear case on Honda435u brush cutter
Under normal cercumstances you don't require to service this, except greasing the gears and that is done as... There is a L key bolt on the right side of the pipe (you should own a L key set) above the blade you are useing,,open the bolt in the normal direction means anti clock wise than insert grease in to the opening till it doesn't start coming out by it self that means its full. Replace the bolt but don't tighten it too hard because it can create problem to open next time.when you now run the brush cutter it will run smooth. On ther hand if there is any other problem than this like gears are broken or something than replace the entire assembly
Sep 24, 2014 | Garden
LIGHTNING BOLT AND GEAR ON SCREEN
I would guess that this means that you have a power problem, if I knew the model I could help more, but maybe you are using more power than can be inputed in the same amount of time.
Nov 15, 2013 | HTC Cell Phones
2000 sierra 5 spd removal
Do you mean flywheel removal? A flex plate is the toothed gear that bolts up to a torque converter on a vehicle with an automatic trans. If you mean a flywheel, which is what a clutch bolts up to, then yes it is highly recommended to remove it and have it surfaced when doing a clutch job. And since you are there anyway I would also suggest replacing the rear main seal
Dec 30, 2012 | Cars & Trucks
Why wont my 2000 audi a4 move when i switch it into gear
2000 audi a4 is built with a transaxel meaning all tires rotate at the same time with the same energy, there is 2 bolts under the transaxel which are to fiil wth transaxel oil front and back need to see if you have enough oil in these 2 plases front its easy as you take the bolt off if you have driping oil its ok other than that add oil, rear itsdifferent you must take the bolt off and insert your finguer trou and see if you can touch the oil if not you must buy a pump to pump oil into it when driping out means its full best to buy repair manual to figur out better good luk
Nov 12, 2011 | 2000 Audi A4
What type of oil should i use for my 2003 Cr125? Also how much does it hold? and i dont mean gas oil mixture i mean the straight oil you have to put in the motor
i use 80/90W pro honda gear oil in mine and there is a over flow bolt on the left side of the motor that if you pull that out just keep puttin oil in until it comes out the bolt hole than it is full.
May 23, 2011 | 2003 Honda CR 125 R
My speedometer on my 05 gsxr 600 stopped working what do I need to check before buying a new ome
when you say stoped workig do you mean no digital desplay at all when you turn on the ignition, does this bike have an aftermarket gear indicator,? remove the screen and check at the rear of the clock for any broken wires, have you recently had a new front sprocket fitted, if so it is possible you have desturbed the speedomiter drive which is located in the sprocket cover secured by an8mm bolt check the wire conection from the drive follow the wire up you will find a plastic conector, check that it is joined corectly by pushing top and bottom together, it may well be that this unit is burned out a resistance must be found at this unit using a multimeter.also behind the case located on the front sprocket is the drive gear this is secured in the gearbox shaft with a 8mmm alun bolt check for security if the bolt is loose the drive will spin on the shaft and speed will not be recognised,
Oct 27, 2010 | Suzuki GSX-R 600 Motorcycles
My 220 i vibrates at low speed,espcially when i shift to higher gears.. what could be the problem, could it be solved ?
get fix and thightly fix the bolts of Swing Arm( also check if bushings are loosen),and fix tightly the bolt where the engine and the chasis connects.( the are two bolts on it ).
if you cant understand what i mean ,you just send me again question so that i could help.
Nov 05, 2009 | 2007 Bajaj Pulsar 180
1995 Olds Cutlass Supreme. My transmission is shot
Not sure exactly what you mean but the 4t60E comes with lots of different gear ratios. Just because a replacement one will bolt in doesn't mean it will work. If you are going to replace it, it needs to be the same gear ratio. If your car has a 3.1 I think the gear ratio is 3.33 and if its a 3.4 it is a 3.06
Aug 23, 2009 | 1995 Oldsmobile Cutlass Supreme
What gear is in the 92 chevy cheyenne 4.3 5 speed
What is the gear ratio for your vehicle? I'm not sure if that is what you mean, but there should be a metal tag under one of the bolts at the pumpkin on the axle that should tell the gearing ratio for that vehicle. Hope this helped.
Jul 16, 2009 | 1992 Chevrolet K1500
Nokia Lumia 920 Logo
308 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
