Question about Ruud UBHC Air Conditioner
Cool air through vents
The motor is running but no heat ruud urgg-10E30JKR it is gas and electric cool air is coming through the vents
  • mopar440man May 11, 2010
    does heat fire off. is the fan running all the time
I replaced the unit it was very old
Posted on Jan 27, 2009
WIRING DIAGRAM FOR RUUD URGG-07E37JKR
Just go to the following web address. Hope this helps!
https://www.google.com/search?q=Ruud+model+URGG-07E37JKR+wiring+diagram&rlz=1C1SKPL_enUS
Jan 17, 2015 | Ruud Central System Air Conditioner
What type of run capacitor do I need for a Ruud AC model UPNJ-031JAZ (outside unit)
Looks like it should be a 35/3 370VAC. If it is not legible on the old capacitor read the data plate on the fan motor and compressor. These should say "uf" or "mfd" rating. Good Luck!!
Apr 17, 2017 | Heating & Cooling
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Feb 15, 2009 | Ruud UBHC Air Conditioner
What size is my ruud gas pack
you have a 92' three ton unit in the mod # the 37 signifies 37000 btu, and the servial number states that it was made in the 44th week of 1992.
Feb 06, 2009 | Ruud UAMB Air Conditioner
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
RUUD model URGG-10E31JKR GASS PACK purge fan and main blower
if the purge fan wont start on its own see if there is a capactor attached. if not replace it. more than likely you cannot lube the bearings in your blower motor. the new fans are not serviceable.
Oct 29, 2008 | Ruud Heating & Cooling
Electrical Schematic for Ruud URGG-10E37JKR
just a maybe , write to RUUD AT P.O. BOX 17010 , 5600 OLD GREENWOOD ROAD ,FORT SMITH ARKANSAS, 72917-7010, OR CALL 479-646-4311 AND SEE IF THEY CAN TELL YOU WHERE TO CALL FOR SAM.
Sep 20, 2008 | Ruud UAMB Air Conditioner
Ruud UBHC Air Conditioner Logo
114 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
