Question about Fuji Finepix Z20fd Digital Camera
I have a finepix z and I can only view the pictures that are in the internal memory not the memory card. What is wrong with it?
    Genius:
  • 1,019 Answers
Change the setting to memory card instead of internal memory.
Posted on Jan 26, 2013
simplemitch
  • 752 Answers
SOURCE: FinePix Image Memory Card reader DPC-R1
Usually the filename is how they are sorted, i.e., 001.jpg, 002.jpg, 003.jpg.... Check on the camera's setup menu to see what method is being used for file naming (for instance, it may be organizing based on date stamp, instead...).
Posted on Aug 05, 2008
SOURCE: screen reading memory card not initialized
help me i also have the same problem please email me how you fixed the problem? cdcdcmiura@hawaii.rr.com
mahalo's
Posted on Feb 24, 2009
robmcd27
  • 423 Answers
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Posted on Mar 09, 2009
mjjdesigns
  • 98 Answers
SOURCE: Internal memory to memory card
Generally, it's not possible to move images from internal memory to a memory card, which poses a problem because you can't connect that camera to your computer.
Most digital cameras keep the internal memory separate from the memory card. Not sure why, but they do.
It's unlikely that you'll be able to get those photos off, if the camera isn't recognized by the computer.
Posted on Mar 19, 2009
welcomejee
  • 10594 Answers
SOURCE: how to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
Posted on Jun 17, 2009
I can't view images on Internal memory when SD card is inserted.
Put the card in, then select "Copy" from the playback menu. You will then be given the option of copying individual images or all of them. See the instructions beginning on page 99 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s5700_s700_s5800_s800_manual_01.pdf
Jul 11, 2013 | Cameras
**Help** The pictures I just took are gone, and its now on Internal Memory?
I believe you can take the memory card out and go to view pictures and when you find the pics that are on there select the pic and then hit the menu button on camera or settings button!! it should ask to send to memory card but first take memory card out and make sure that they are there then insert card and hit settings on the picture and select to send to memory card
Mar 25, 2012 | Fuji FinePix Z10fd Digital Camera
I want to view the pictures on the internal memory
Hi vicki. The camera probably only displays the pictures in internal memory when there is no extra memory card in place, so you will be able to see them if you take it out and then switch the camera into its review mode. Hope this helps
Dec 28, 2010 | Fuji FinePix A340 Digital Camera
My Fujifilm s5000 camera turns on but when I go to take a picture it turns off. I can view my pictures but can't take any.
Your memory card or internal memory may be full. I've run into situations where the card full doesn't flash on the monitor or LCD screen because there is lets say 3 gigs of memory left but the picture you are taking is 3.5gig's it won't take the picture because there isn't enough memory to put the image anywhere. Download your pictures to your computer, format your memory card and all should be good again. If you are using the internal memory you will need to obtain (buy) a memory card for your camera and download from the internal memory each picture from the memory card one by one until all the internal pictures are on the removable memory card then download these to the computer. After you have them on the computer go back into the internal memory and delete each of thse pictures and you are ready to start taking pictures once again. it took me longer to type this then the process will take to do.
Dec 24, 2010 | Fuji FinePix S5000 Digital Camera
How can I transfer my pictures from Fuji FinePix S5700 Digital Camera internal memory to a SD card
I don't know if there is a function to do this on your camera, but on the cameras I am familiar with, there is not.
However, if what you want to accomplish is to get your pictures from internal memory into your computer, there is a way. Simply remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
Nov 06, 2010 | Fuji FinePix S5700 Digital Camera
How do i get from internal memory to external memory on the finepix Z20 camera?
I think you mean you want to transfer pictures from the internal memory to the memory card. I don't know if there is a function to do this on your camera, but on the cameras I am familiar with, there is not.
Oct 30, 2010 | Fuji Finepix Z20fd Digital Camera
My finepix j10 is saying that the memory is full after 53 pics and i have a card that holds 2100 plus the internal what is wrong? is it the camera or memory card?
You need to download the pics from the internal memory and then format it with no card in the camera. Then, your memory card should work.
Aug 08, 2010 | Fuji FinePix J10 Digital Camera
The camera says memory is full but I have only taken about 20 pictures - the letters IN appear in the corner - camera is a finepix F31fd
You are taking pictures to the internal memory and not to the XD Picture Card. The internal memory will only hold about 20 pictures. You can buy an XD Picture card at Walmart or really any store that sells camera accessories. 256MB should be plenty.
You can also lower the resolution of your pictures and then the internal memory may hold maybe 32-40 pictures.
May 05, 2010 | Fuji FinePix S3000 Digital Camera
Internal Memory is full
Your camera should automatically recognise when a memory card is inserted and store pictures on to that rather than use the internal memory. The internal memory is only used when no card is inserted so possibly there is a fault with the card connections if it does not recognise when it is inserted.
To clear the internal memory have a look at my post on my tips page on my profile dealing with this.
Jan 18, 2010 | Fuji FinePix A900 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
Fuji Finepix Z20fd Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
