Question about Roper Microwave Ovens
Roper Microwave 2652000
Specs
How to locate fuse in Roper microwave model No. MHE14XKB
After removing the cover (most microwaves use security screws) the fuse will be on the circuit board near where the power cord connects. It will look like a glass fuse but is made of ceramic. Most have pigtail leads and are soldered directly to the board. Do not ever operate a microwave with the cover off.
Aug 18, 2016 | Roper Microwave Ovens
My Roper Microwave hood Combination (microwave) has stopped heating. What could be the problem?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ---][\
Apr 13, 2011 | Roper MHE11REQ Microwave Oven
Roper microwave has broken glass in the door
Whatever you do don't use the microwave until you replace the door. You run the risk of possibly shattering the glass or being exposed to dangerous microwaves from the oven. Get on the Roper web site and find a replacement for the door. You never know there could be a recall for safety issues on your particular model.
May 02, 2010 | Microwave Ovens
Can't get roper microwave oven to heat
heatman101
dhhdg
Apr 22, 2010 | Roper MHE14XKB Microwave Oven
I have a roper mounted microwave above my stove. i just need to know what kind of bulb goes underneath it.
Since you obviously intend replacing the bulb yourself (good for you!) you should first remove the old bulb and that will make it easier to find a new one. Chances are, its a common bulb, readily available wherever light bulbs are sold. Or, at the very least, a hardware store like Tru-Value or Home Base.
Feb 03, 2010 | Roper MHE14XKB Microwave Oven
I have a Roper Microwave mounted over my gas stove
Usually you should have at least 12" - 18" AND a fireproof "Barrier" as the "Roof" of the stove "Floor" of the microwave shelf.
Jan 20, 2010 | Roper MHE14XKB Microwave Oven
Roper Microwave (mhe14xmq dec. 2003) trips breaker...
you might have to reset your your power settings on the micro.
Sep 21, 2008 | Roper MHE14XKB Microwave Oven
I have a double roper oven Model #39758B0 Serial # 8Roo896 Problem when turning the top oven on I get an F-5 signal and the oven does not turn on. I need to know how ro fix this problem. Thank you, Rita...
My problem is with a roper double wall oven not a micowave. When turning the top oven on I receive a F-5 signal and the oven does not turn on. I misplaced my manual hoping you can solve this problem or send me the manual.
Thank you,
Rita
Sep 16, 2008 | Roper MHE14XKB Microwave Oven
Plastice door covering and handle
htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Roper Microwave Ovens
Microwave Ovens Logo
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
bigdawg7299
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
