Question about Doro PhoneEasy Cell Phones
Doro phone easy 409 screen has gone blank
Screen has gone blank. I must dial direct to obtain a call
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
SOURCE: blank screen
i have the same phone and the problem just lies on the flexcable inside the phone that attached the keypad to screen.
Posted on Dec 10, 2007
SOURCE: sony ericsson w850i blank screen
I am having the same problem with my w850i, poweres up but nothing more than a blank screen? Any suggestions?
Posted on Apr 16, 2008
issaconan
  • 115 Answers
SOURCE: blank screen on nokia n95
in you case, there is two probabilite :
- the screen
- the nape
and yhe nape is the moste probabilite, it's a small nape for the connexion betwen the screen and the mothercard.
in all the case this intervention need a professionnel intervention, i don't advice you to do it by your self if you are note.
good luck;)
Posted on Nov 20, 2008
Dipu007
  • 2110 Answers
SOURCE: blank white screen
It seems to be ur lcd stops working..Take this to service center...
Posted on Nov 29, 2008
The time display has gone blank. When I switch on temp dial the red oven light flickers. When I switch on fan dial nothing happens
Assure full power is available to the unit(220 volts-not 2 times the same 100 volts). Depending on the model, and age of the unit, the circuit board behind the clock is failing or has failed. The timer board directs timed power for the oven, shows the times, and may have other features. Any elements are usually directly controlled by the knobs without going thru the timer board. When the timer display disappears and stays blank no matter what you do, even turning the breaker off and then on again , then power thru the board has failed. This could be caused by mass failure of the board(burned out-burned parts-vaporized parts) right down to a couple simple components that have failed due to age and don't pass the power onto the circuit.. High voltage is present and any troubleshooting should be done by a competent person for that task. Be safe.
Apr 27, 2015 | Ovens
My phones are going blank on screen after I dial out or while dialing.
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Nov 21, 2014 | Uniden DECT15803 3 handsets and Chargers -...
My phone screen has gone blank
It would make more sense to contact Doro (in your country) rather than posting a general question here.
Support Information and contact details Doro Easy to use mobile phones and...
Nov 17, 2014 | Doro Lands Phones
I can't seem to put the speed dial numbers into doro phone easy 331
that means u gata get ur self a new phone but first burn that one, it`s now useless...
Apr 30, 2012 | Doro PhoneEasy Cell Phones
Screen gone blank nokia e75
i just had this problem. i tried formatting it.
dial *#7370# and lock code is 12345
be careful thou everything will be restarted.
Sep 07, 2010 | Nokia E75 Cell Phone
My LG screen froze and now it's gone completely blank.
nice day,,try to dial your phone if you hear a voice its mean ,,the problem of your phone is lcd or display ic...but if you never hear a voice the problem is software try it to reprogram ,,go to the cellphone repair shop..good luck..
Jun 22, 2010 | Cell Phones
Doro 410 mobile phone. Just bought today - screen blank.
Some phone needs batteries in it or a power supply plugged into it if both are good the return phone it defective
Jan 18, 2010 | Doro Phone Easy
My screen has gone blank and although I can still dial I can't see the screen to scroll through the address book etc, read texts
Hi there, You need to get the flex changed with a new one. When the flex goes bad, it affects the screen and eventually the ear piece where you will not be able to hear the person who calls even though they hear you.
Thanks & All the Best
Dec 12, 2009 | Samsung SGH-T339 Cellular Phone
Inside screen has gone blank and is now only white. How to get it back to normal? All my icons are gone and you can not see the number you are dialing.
Your screen has died on you mate. Either get it replaced at your local phone shop or try to repair it yourself although I wouldn't recommend it.
Dec 05, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
81 people viewed this question
Top Doro Cell Phones Experts
Computer Repairing
Computer Repairing
 Mikey
Mikey
ray gallant
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
