Question about Clarke Tools & Hardware - Others
Clarke du8 floor sander manual
Manual for clarke du8
  • 13 Answers
SOURCE: clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
Posted on May 25, 2010
rowdy45176
  • 2176 Answers
SOURCE: My belt sander is eating away to much on the left
I would first look at the discs for uneven wear but if you want and I would recommend going to "Clarkeamericansander.com" they hae service and support and technical services who can better serve you. they also have tool free numbers listed for assistance. where I work I have called them are they are really there to help. Good Luck
Posted on Sep 25, 2010
rowdy45176
  • 2176 Answers
SOURCE: i have a du-8r clarke
I can't find anything on Clarke's website for this tool. But if you have the switch out I would take it to a local repair facility or electrical supply house and have them match it up. There is usually nothing that special about the switches. Let me know if you cant and I will try and dig deeper.
Posted on Jan 22, 2009
  • 3 Answers
SOURCE: Using a Clarke DU-8R drum sander, I am getting
If the drum has the bar clamp with the 3 screws make sure the bar is set so the screws are flush when tightened down. If you reverse the bar clamp the screws will stick up a fraction and cause this grooving in your floor.
Posted on Mar 21, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a Clarke Model 504 floor drum sander.
I would recomment trying a local rental yard. they usually have the paper and machines for rent. If not let me know and I will do some more research with Clarke, give me your general area with zip code and I will try and find a local source.
Posted on Jan 09, 2011
I have a Clarke Model 504 floor drum sander. where can i find paper for this?
Jan 09, 2011 | Sander Industrial Original Clarke Floor...
My belt sander is eating away to much on the left side and it is also leaving cut lines on the floor.. does anyone have a solution or a guide to how to fix this problem? my floor sander is a "Clarke...
Sep 23, 2010 | Clarke Floor Sander Floor Sander Orbital...
Clarke plate sander vs drum for a floor that only needs
May 13, 2010 | Clarke Floor Sander Floor Sander Orbital...
It seems the sanding table has frozen to the eccentric on my orbital clarke floor sander. Any recommendation on how to get apart. I need to replace the 4 upper bolts with rubber washers. I have tried...
Go to Americansanders.com and under the orbital sander click on it and the manual is 38 pages long, the parts explosion is towards the back of the manual but it should show you how to disassemble this tool so you can get to the bolts that you need. Let me know if you need more help
Sep 30, 2009 | Clarke Floor Sander Floor Sander Orbital...
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
Using a Clarke DU-8R drum sander, I am getting grooves in the floor from one pass to the next, running parallel to the sanding direction. I am sanding right to left as it says. Is there an adjustment to...
Mar 02, 2009 | Sander Industrial Original Clarke Floor...
I have a du-8r clarke floor sander, i need a schurter switch, swiss made, a146f160u4-azm11, 120v, 16 amp. do they still make this part.
Jan 21, 2009 | Sander Industrial Original Clarke Floor...
I have a clarke c-5 edger need parts
I checked Clarkes site and they don't show this tool. Suggest you call 1-800-253-0367 and ask for technical support. I deal with this company on a weekly basis at work and they are great in helping. Good Luck
Dec 13, 2008 | Sander Industrial Original Clarke Floor...
Tools & Hardware - Others Logo
312 people viewed this question
Top Clarke Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Outback Jack
Outback Jack
Are you a Clarke Tool and Hardware - Other Expert? Answer questions, earn points and help others
