Need control for flame electric fire type rcs-o1c
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
NEED REMOTE CONTROL SANYO RCS - 7S1E
SANYO RCS - 7S1E REMOTE CONTROL WHERE CAN I GET?
Aug 07, 2012 | Sanyo 26XHW72R Air Conditioner
I have recently bought a second-hand electric fire which looks exactly like The Adam Ribbon chrome Electric Fire. It has three switches for flame only and then two heat settings. What i don't understand is...
The dial, numbered 1-9, is probably the heater fan speed control. Or it also could be the flame effect control (speeds the flames up or slows them down). But, I suspect its the heater fan speed control. Either way, it works like a rheostat. As far as efficiency is concerned, despite what the manufacturer may say, electric fireplace effect heaters are not that efficient in the long term. Nor, are they that reliable. They do require routine maintenance to increase their longevity.
Hope this answered your questions.
Apr 13, 2011 | Heating & Cooling
Need wireless remote control RCS-KS-1 for Unit PKE-K250AS6A
I have a UNUSED Sanyo remote control RCS-KS-1.
Email me if you still need one.
gwj97@netzero.com
Nov 26, 2009 | Sanyo Split System Air Conditioner
How to install pilot generator (flame detector). Need details on replacing part. I have part, but access is difficult.
Let's start, If you have a igniton control you won't have a pilot generator. A flame detector as you say is a part of a pilot igniton sparker. I'm thinking if you have a ignition control box you have a ignitor and a flame rectifor.(Sematics)
First you need to shut off the gas and pull the gas line from the heater. Now you will find three (I think maybe two) nuts holding the gas valve to the firewall with a bracket. Remove these.
It's hard to saw depending on model what holds the fire tray in but it should be only a few nuts, remove these and pull the tray out. (forgot wires on the gas valve, pull these and lable them)
With the tray out you will see the pilot assembly. It will be obevious how to remove this. When this is out of the tray remove the pilot line from it.
There are two different types of ignition. When you talk of a pilot I think you have a spark igniton and now you get a new part and replace it.
If you have a glow plug, this is a ceramic coil that conducts electricity and get's HOT. Their are two types.(Are you tired of this two types stuff yet, me to) One is cased in a stainless steel cover and should not be a problem. The other will come in a box lined with foam rubber and lots of careful stickers. This is frail so be careful putting it in and replaceing the tray. Any leaks hitting it when it is hot will cause it to fail. (Can you figgure why they changed it) I go into this detail on this one because this is the one that will be a problem on most electronic fire heaters. Sounds scarey but just be careful with it and check for leaks before you replace it or you will do it again. REMEMBER THIS IS A BOX FULL OF FIRE NEXT TO YOUR HOUSE. Careful and good luck, let me know if I helped.
Oct 31, 2009 | Teledyne Laars IGNITION TRANSFORMER
Ignitor continues on it own
Sounds like your cooker has a flame rectifier supervision system. What this means is, electricity is passed through the flame from the controller, back to the controller/pcb (fire conducts electricity). If the the pcb doesn't recieve a return signal, it thinks the burner has gone out and starts the ignition to try a light the burner again. As simple to fix as a rusty/dirty flame rod or, as complicated as a bad pcb. Get a pro to check it out.
Jul 29, 2009 | Stoves Electric Stove With Heater - Blue
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
