Question about Garden
Poulan bvm2000vs leafblower will not start when engin is hot
This happens afer U run ut and is sets idke fir a few minutes
  • 48 Answers
SOURCE: craftsman gas leafblower
All small engines take a few minutes to warm up...especially so as they age.
You have to learn to 'feather' the throttle to very, very slowly increase the gas.
After it is warmed up, you are much more likely able to rev it up...release, etc.
I've had many over the years, and this is a very common problem...that you learn how to handle.
Posted on Nov 06, 2008
panilling9
  • 284 Answers
SOURCE: brand new leafblower first use and it stalled
hopefully unless it is a 4 cycle? you mixed 2 cycle oil and fuel together as one and put it in the fuel tank? you can use a 40:1 mixture 3.2 oz of 2 cycle oil to 1 gallon of fuel 87 octane will work or 89 octane is better.
if its a 4 cycle (10w-30 for oil) and fuel go in a seperate area?check your manual to verify what they would like you to use
Posted on Jul 03, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a gas powered weedeater BV 1700 leafblower
1) determine copression of engine
2) check for spark
3) check that the plug is wet or dry
Posted on Nov 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
I just worked on my craftsman leaf blower that would only run at half choke. I tried cleaning the carb and also cleaned the exhaust port. Didn't help. Then i took the cover off and noticed that one of the head gasket bolts was loose. Tightened the head gasket bolts and then it ran fine. Must have been sucking some air.
Posted on Aug 01, 2010
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman gas leafblower
Nov 06, 2008 | Garden
2000 Tacoma leaking fuel from evap canister
check your fuel vapor canistor for restricted vent line there could be a possible orfice valve inline towards tank wich would not let the tank breathe causing vapor lock
Jul 29, 2008 | 2000 Toyota Tacoma PreRunner
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
