Question about Zonet ZPS1002 USB 2.0 Print Server
Zonet ZPS1002 1 Port USB 2.0 Print Server
Webconfiguration utility
2 Suggested Answers
gwbm
  • 353 Answers
SOURCE: Epson stylus C44UX and zps1001 zonet print server
Since it's over a year since we had any response on this, I think we might call it "Solved by Poster".
Posted on Mar 15, 2009
I need a setup cd
Request the setup CD directly from Zonet.
Jul 23, 2014 | Zonet Zpw4000 1 port Usb 2.0 Wireless...
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Zonet zps1002 firmware
where can i get the current firmware download for Zonet ZPS1002 print server?
Jul 05, 2012 | Zonet ZPS2102 Print Server 2xusb2.0 &...
How do I find the new IP address for the Zonet ZSP3611 Printer Server so I can set up my printer to work
An easy way would be to download and install nmap. For the IP address to scan, if your computer ip is say, 192.168.0.52 then enter 192.168.0.0/24 and select the quick scan. Whichever device comes back with an open port of 9100 is most likely the print server.
May 08, 2012 | Zonet ZPS3611 Print Server
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
Jan 30, 2011 | Zonet ZPS2102 Print Server
How to contact sys-admin(wiz)
Plug the print server in the back of your computer using the ethernet port. Insert the setup cd into the same computer. Assign an IP address for you print server using 10.10.10.xxx. xxx=available address number on your network. If it requires the gateway address use 10.10.10.1 if that is the correct address of your Linksys router.
You can verify the correct router address from your computer. Make sure your computer is connected to the network (not the print server) and go into the control panel. Select Network Connections. Move the mouse to you network card. Press the right mouse button and select status. The gateway address is your router address.
Jan 06, 2009 | Zonet (ZPS1000) Print Server
Jan 13, 2008 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Zonet ZPS1001 can't detect Konica Minolta Magicolor 2400W
Persever. Change your usb points, and at the last resort get the cord from your old printer and use this type of connection. Go slowly thorugh the disc step by step and make sure you delete any previous installations of the print file in the control panel.
Oct 28, 2007 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Zonet ZPS1002 USB 2.0 Print Server Logo
47 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
